need help to diagnose. 89 Camry 3S-FE no start
Google
Web AF
capoeta
03-06-2006, 01:24 PM
I need help to diagnose a no start camry.
Timming belt slipped and Dizzy burned due to oil past o-ring.
I've replaced Belt, set cam/crank timming and replaced Dizzy on car.
Now car will not start. I checked spark at plugs and I get spark across all plugs when grounded against metal. What I don't know is, if the spark is strong enough.
I did a search in forum and found a post that recommended to scope the Dizzy and wire to determine dizzy voltage output. Does this mean I probe the dizzy as it is fireing with the Voltmeter?
Also, How do I interpret the pickup coil "resistance test"... I checked the resistance and i get momentary flashes of the reading for a second and then it dissapears... Is this normal?
I'm having a difficult time figuring this one out.
Thanks in advance for the help.
somick
03-07-2006, 03:09 PM
The intermittent readings on the pick up coil sound like you have found a problem. There must be a poor contact or a broken wire.
Sam
Google
Web AF
