A cold dead S10 and On FootBob S. 03-04-2006, 07:49 PM My baby (1989 4.3 Liter S10) has went and let me down. It was really cold the other night after work and I jumped in expecting a quick trip home. She started briefly then immediately died, never to start again. I came back the next morning and tried a little starter fluid but no success. Then I pullled the coil to distributor wire and turned the motor over. No spark. I tried a few times more and finally got a yellowish single spark that arched to the threaded rod which secures the air cleaner cover...and that's all she wrote! I swapped the coil out of a 1988 4.3 liter S10 that I have and nothing happed. I put the coil in question from my 1989 back into the 1988 and it seems to run fine. My coil seems to be OK. Could this be a dead pick up coil or is there something else I should be checking? Bads Crew 03-04-2006, 08:12 PM Look at the post below yours. Bob S. 03-06-2006, 04:54 PM Look at the post below yours. Thanks for your suggestion. It turned out to be a bad ignition module. I found an unused original equipment module on ebay for less than half the price and took care of the problem. My baby is out of the dog house. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
