where is it ?
Google
Web AF
kimbergross
03-04-2006, 01:10 PM
i have a 1999 z24 iam fixing up the head light and door chime do not work .i checked the fuses they look good but i do not know where to look for the chimes does any body know where they are located at on a z24 thank for any help
04_CaV!!
03-05-2006, 10:14 AM
I believe with your car the chimes are located in all places your radio. I beleive thats why when someone replaces the stock headunit for an aftermarket one they suggest to relocate the stock radio to the trunk, so you can keep your chimes. Not sure how to go about fixing a falty one though.
kimbergross
03-05-2006, 11:16 AM
i have a 1999 z24 iam fixing up the head light and door chime do not work .i checked the fuses they look good but i do not know where to look for the chimes does any body know where they are located at on a z24 thank for any help thanks i can use all the help i can get kimber
OverAllComa
03-05-2006, 11:53 PM
That problem is easily solved with the proper wiring kit. A generic kit generally won't have the right wires, but a GM specific kit will include what you need to take care of the door chimes. I had mine bought and installed at Best Buy, who, IMO, does decent work especially for a non-specializing chain store.
kimbergross
03-06-2006, 06:50 AM
That problem is easily solved with the proper wiring kit. A generic kit generally won't have the right wires, but a GM specific kit will include what you need to take care of the door chimes. I had mine bought and installed at Best Buy, who, IMO, does decent work especially for a non-specializing chain store. thank for info kimber
BlasZ24
03-06-2006, 11:47 AM
For a 99 I dont think that is going to be your problem its on the 2000 models and later that they changed the chimes to go through the radio. In which case if you want to keep them you need to buy a $150 wiring harness just to keep them. But lucky for you, you should be able to just buy the $15 generic GM harness and all should be well.
kimbergross
03-06-2006, 12:03 PM
For a 99 I dont think that is going to be your problem its on the 2000 models and later that they changed the chimes to go through the radio. In which case if you want to keep them you need to buy a $150 wiring harness just to keep them. But lucky for you, you should be able to just buy the $15 generic GM harness and all should be well. thank for your help
Google
Web AF
