Ok maybe someonecan help please
ecg2647
03-02-2006, 05:16 PM
Lets ee I have a 94 bonnie. changed plugs,Wires,O2sensor,EGR Valve, new coil pack(only one) and new belts. Ok car acts like it wants to stall when I start it not while driveing it after a few short trips. If I go long trips car is fine if i do short run and start stops I have trouble not always just once in awhile if i let car sit and putter for a few mins it will catch its self and i can drive off no problems when it doe sthis there is a terrible exhaust smell cant really describe it not like when muffler has a hole but its definite exhauste im going nuts here .ready to sell car for a PENNY at this rate. It will run fine then if i have to do alot of little trips it will start but has a very weak reaction if i pump the gas its like its not there at all once it gets going its good. I did notice the neg battery wire is bad had Autozone order me one today.I alos need a new muffler but not the problem I dont think. I need this car my daughter has to travel to Allentown to the Womens cancer center and she is also pregnant and Im at a loss I cant figure out this D*mn car). I did have it coded I was told it had lots of stored codes so cleared them and i got these ones
cruise control
tourqu sensor
EGR pintel position sensor(reason i changed egr valve at $130.00)
ANy help or cheap labor would be a helps please also
Thanks
Shelly
auto trainy
03-02-2006, 08:17 PM
Have someone check your torque converter lock up switch or the sensor associated with it,good luck
sixsmiles
03-06-2006, 08:27 AM
Is there any way you can have someone remove the Catalytic Converter for testing, then replace the converter if it is the problem?
maxwedge
03-06-2006, 11:13 AM
Yes, or just drop the pipes down, or use a non contact thermometer, get it to operating temp, check the inlet temp vs the outlet temp the outlet should be signficantly hotter, if not the cat is blocked or lost it's effiiciency.
richtazz
03-09-2006, 03:37 PM
you can do a back pressure test at the front oxygen sensor port, back pressure shouldn't exceed 1.5 psi
Duece66
03-20-2006, 03:40 PM
Sounds like your catalytic converter is plugged. Does it smell like rotten eggs my buddy had that problem. Car ran like crap ! Good luck !
