runing lights
Google
Web AF
blaze-420
03-02-2006, 12:28 AM
would anyone know how to shut off the runing lights without depressing the parking break. tanks
BlazinMlew
03-02-2006, 12:32 AM
on my 2000 you can just press the dome override switch 4 times and hear the "ding" and the stay of until you turn the vehicle off and then back on again. Or just press the button 4 times again and turn them back on.
joblo33
03-02-2006, 12:47 AM
And if your vehicle is older than that you could just put the brake down one click, before it actually affects the braking. That's what I do for my 93 s10.
Eric
Gabe25
03-02-2006, 02:41 PM
You didn't indicate what year your truck is. So I'm going to asume that it a early year. Here you go. I hope this helps you.
1. Locate the fuse block under the hood on the drivers side of the engine compartment.
2. Remove the cover by unscrewing this knob. Note: This knob does not come out of the cover.
3. Once the knob is loose, the cover will pull off.
4. Underneath the cover is a diagram of the fuse block. Locate the position of the relay labeled 'DRL'.
5. Locate the relay on the fuse block and remove it.
6. Ok, here is the important part. On the bottom of the relay, you will see 5 prongs with the numbers 30, 85, 86, 87, and 87a.Take your pliers and bend the prong labeled 86. This will prevent that prong from engaging the fuse block, deactivating the daytime running lights.
7. Replace the relay. Line up the prongs with the holes in the fuse block. It will only go back in one way.
8. Replace the cover and tighten the knob. You're Done!
gman2153
03-02-2006, 08:24 PM
Gabe - will that same technique work on a 2002?
I shut mine off via the dome override button,but if I can bend that pin over and de-activate them all the better.
Booch
03-02-2006, 08:33 PM
Yes; I did this same thing to my 2002 Xtreme; works great.
blaze-420
03-03-2006, 01:44 AM
i would like to think you all. i am going to try the dome over ride in the morning.
Gabe25
03-03-2006, 03:30 PM
Yes it should work.
GabeT
09-17-2006, 10:24 PM
Gabe Thanks for the How-To. I vote this becomes a sticky post. I'm sure there are many people wanting to learn how to effectivly disable the DRL feature.
BlazerBoyLT98
09-20-2006, 03:03 PM
On my 98 in the fuse block I have a fuse labled DRL and all I did was pull that out and wouldn't you know it..... no more day time running lamps
Google
Web AF
