rear brakesmarcre 03-01-2006, 05:32 PM I've decided I'm going to replace my rear brakes myself (I am going try at least). I've never done this before. Is it real difficult? My haynes manual has a step by step instuction, so hopefully that will help. It says nothing about bleeding the brakes. Do I have to do that? My pads came with some lubricant. One is orange, the other is brown. What are they for? (I assume one is anti squeal and the other may be high temp grease). Where do they go? My rotors are 3 years old, should I even take them off and get them resurffaced? Where could I get that done? More questions to come? Also, if anyone knows of a good brake change write-up, let me know. I could use all the help I can get. thanks, marc amigo-2k 03-01-2006, 06:08 PM There use to be a write up on whats in the box (well it was a photo with discriptions of each part). the guys user name was JasonB (he owned a 99 Amigo), and he has a geocities site (might be worth a google). I would try to contact him to see if he still have the photos yet. Ramblin Fever 03-01-2006, 07:04 PM Well, you know how many miles I have; I'm currently on the 3rd set of brakes all around, but have never had to resurface or replace rotors. FWIW - I do not recommend brakes from Autozone, truck went through them within 25-30k miles. I highly recommend to make certain to bleed and bleed the brake system when you're done, then take her around the block, come back and bleed once more. surferfletch 03-01-2006, 09:02 PM My fronts are finally due for a resurfacing. I get some pulsing. Clean up and lube the caliper pins well and do be sure to bleed the brakes. The Haynes is pretty good for the brakes on my '97. You can do it. Just take your time. marcre 03-01-2006, 09:24 PM anyone know what those packets of grease are for? Canucklehead 03-01-2006, 10:03 PM anyone know what those packets of grease are for?One is for the caliper slide pins, not sure which though. marcre 03-01-2006, 10:14 PM There use to be a write up on whats in the box (well it was a photo with discriptions of each part). What is "what's in the box"? amigo-2k 03-01-2006, 11:40 PM http://72.14.207.104/search?q=cache:dXWaHNjP3H4J:forum.planetisuzu.com/viewtopic.php%3Fp%3D541%26sid%3D8ed201f1d4dca96da4 99d492786089b0+jasonb+isuzu+brake&hl=en&gl=us&ct=clnk&cd=3&client=firefox-a http://club.vmag.com/ubb/Forum6/HTML/000127.html rodeo02 03-02-2006, 12:35 PM Dang Marc. I wish I would have known! I have a brand-new, in the box rear pad kit from St.Charles sitting in my workbench drawer. I have no use for them now :rolleyes: . It for a 2002+ tho. Not sure if that makes a difference (front brakes are way different on 2002+). I ordered brakes all the way around awile back, but the backs were still good yet. If anyone wants the rear pad kit for a 2002+, I'll give them to you. Just pay the USPS shipping. zip = 14170. G/luck Joel Gizmo42 03-02-2006, 12:37 PM I finally got around to doing my rear brakes last weekend (did the fronts a few months ago). Disk brakes are easy, basicly remove the lower caliper bolt/slide pin, flip the caliper up and slide it off the bracket, replace pads, push the caliper piston in, put it all back together. I didnt bleed my brakes. If you dont have a leak or get the fluid low enough to suck air into the system there really is no point. Though when the weather gets warmer I'm going to flush the system with new fluid. I only had my rotors turned because the surface was in bad shape from the years it spent in wisconssin. That took the longest because I had trouble finding someone that could turn them that was open on a sunday. Most of the places I went didnt have an adapter for their brake lathe big enough to work on them. I didnt bother having the parking brake drums turned. BTW, I have Satisfied Pro Ceramic pads on mine. They might dust the wheels a bit more and may not last as long as OEM (will find out eventually) but I like their pads and this thing will STOP! marcre 03-02-2006, 03:25 PM thanks for all the replies. It looks like I should be able to do this. Any idea which is which when it comes to the two packs of lube? Orange and brown. Also, the one that is the anti squeal, where exactly does it go? Marc billindelicato 03-03-2006, 01:02 AM thanks for all the replies. It looks like I should be able to do this. Any idea which is which when it comes to the two packs of lube? Orange and brown. Also, the one that is the anti squeal, where exactly does it go? Marc anti squeel goes on the back plate of the brake pad itself(brown lube) the orange is the slider grease for the caliper...the groove you set your pads into rodeo02 03-03-2006, 11:54 AM I didn't use the OEM packets with mine. I've got jar of permatex 'synthetic' silicone brake caliper grease. It's green and super sticky. The stuff hangs around a loooong time on pad slides & seems to have worked well on the brake jobs I've used it on. It better be good stuff, I think I paid like $14 for jar from carquest. I'll prolly be able to pass it on to my grand kids :uhoh: . Joel marcre 03-03-2006, 03:35 PM Thanks for all the replies, I think I'm ready to tackle this. I just need the weather to cooperate. I have aquestion about the calipers. I am just curious what kind of calipers I have. Floating, sliding or fixed? marc kenc195 03-07-2006, 02:21 PM When you seperate the calipers, be sure to open the brake bleed zert to let the fluid out. DO NOT just let it flow back into the resevoir. It usually has all kinds of crud in it and you may find yourself replacing the master cylinder sooner then needed. Brake fluid is cheaper then a master cylinder. If your really ambitious you may want to purge all the fluid and add fresh. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
