Problem here...
sganc4life_4
02-27-2006, 03:52 PM
Well, basically my lower radiator hose was rubbing against my slave cylinder and a hole formed. How can I get it not to rub, would zip ties be ok or what?
-Josh-
02-27-2006, 03:55 PM
If there's a bracket nearby you could try and zip tie it to said bracket. Or wrap the hose in some material.
sganc4life_4
02-27-2006, 03:58 PM
Well I was thinking a wrap, but what would i wrap it in? The slave cylinder basically wore a very small hole but like 1/4 of an inch in diameter.
ez1286
02-27-2006, 04:06 PM
I would say firgure out a way to move it, like zip-ties or something, cause if you wrap it it will eventually wear through that too.
sganc4life_4
02-27-2006, 05:18 PM
Thats what I thought, man this sucks. Its been one thing after the other lately....first my accident, new front end...next my balance shaft belt and CPS....and now this.
Blackcrow64
02-27-2006, 05:46 PM
You could put some type of metal sleeving over the radiator hose and then use clamps to keep it where you need it.
Thor06
02-27-2006, 06:18 PM
You could use some heat wrap too. Kinda ghetto, but I think it would work.
ned032002
02-27-2006, 06:51 PM
I would just zip tie it to something like you already said, wrapping it will only delay the inevitable and the hole will reappear.
sganc4life_4
02-27-2006, 06:53 PM
I might do a bit of both, if I cant find a close spot, ill loop like 5 together and go to the frame lol. But i think if I do a metal sleeve too it cant hurt, Ill just have to check it every so often.
george536
02-27-2006, 07:14 PM
wrapping it will only delay it, but its better protection. i would find a way to make them completely not touch, and still have it wrapped just incase it rubs again.
sganc4life_4
02-27-2006, 07:28 PM
Sorry I should have been more clear, Im going to zip tie it, and wrap it just incase. That way if something does break, Ill have more time from it having to eat through metal instead of rubber.
