96 winstar no air condition on rear
manh
02-25-2006, 08:14 PM
My 3.8 96 winstar has 75k miles when turn on air condition only in front row has air , back seats come out hot air , check all fuses are OK. Anyone has simmilar problem please give advise, Thanks alot. also ABS light comes on intermitten.:eek:
LeSabre97mint
02-25-2006, 09:55 PM
My 3.8 96 winstar has 75k miles when turn on air condition only in front roll has air , back seats come out hot air , check all fuses are OK. Anyone has simmilar problem please give advise, Thanks alot. also ABS light comes on intermitten.:eek:
Hello
It sounds like your blend door in the rear has problems. Do a search on the Windstar forum for blend door" and you should come up with some good info.
The reason why I say it's the blend door is because your air is working in the front and both the front and rear use the same compressor for the air.
Regards
Dan
98er
03-10-2006, 05:42 AM
My 98 did this as well. The control switch that adjusts rear fan speed (right most control on front dash) is bad. Replace it. Done.
