Finally! Pics of my CRX SI
lxndr
02-24-2006, 07:07 PM
Finally took some pictures of my '86 SI! I've been on the AF for 2 years now and never got around to it!
http://www.redpepperracing.com/gallery/d/129982-2/IMG_2078.JPG
'89 D16A1, Bored .5mm, P&P head, 10:1 CR, Ported 2G CRX ZC intake manifold, ZC cams, Megan F22 adjustable cam gears, AEM FPR, B&M FPG, '95 Civic fuel rail, and a DC Sports header. Also, rebuilt tranny with LSD.
http://www.redpepperracing.com/gallery/d/130000-2/IMG_2080.JPG
If you look closely you can see the '90 CRX SI seats
http://www.redpepperracing.com/gallery/d/129997-2/IMG_2087.JPG
1 piece carbon fiber ZC hood (header panel molded into hood, ZC bulge to clear DOHC timing cover)
http://www.redpepperracing.com/gallery/d/129994-2/IMG_2086.JPG
17" wheels (for now)
Here's a link to the rest:
http://www.cardomain.com/ride/2278318
Enjoy!
Enjoy!
cvcc_wagon
02-25-2006, 03:15 AM
looks great!
lxndr
02-25-2006, 04:10 PM
Thanks
It's a work in progress, I just started working on the exterior.
My order for building a car is:
1) Stop fast
2) Corner fast
3) Go fast
4) Exterior
5) Interior
1) Stop fast
2) Corner fast
3) Go fast
4) Exterior
5) Interior
kicker1_solo
02-25-2006, 05:17 PM
wow, that's a hot little 1st gen, I like it.
aquarius
02-27-2006, 06:04 PM
nice! smooth and clean looking good!
cvcc_wagon
03-01-2006, 02:11 AM
where's the nice style'n Seattle road grime?
mwrobe1
03-01-2006, 06:13 AM
Wow...really nice. Most of the older Civics I see are either pimped out, riced out, or are rust buckets with a 3 foot spoiler on the back. Good job.
G-man422
03-01-2006, 06:26 AM
looks sweet w/ the CF hood.
lxndr
03-02-2006, 06:36 PM
Washed it off before the pics. But don't worry, it's already covered in dirt again!
Are you ever on RPR anymore?
cvcc_wagon
03-02-2006, 11:38 PM
it's been quite a while since i've checked up over there, been far too busy. now that i'm finishing up with school i will probably try to get back into the swing of things
Tarron.shelton
03-06-2006, 08:09 PM
Hey the car looks great!!!!!!!!!! where did u get that awesome hood from?
lxndr
03-06-2006, 09:25 PM
www.heeltoeauto.com, it's not listed on their website but if you email Marcus he'll take care of it for you.
You can also find more information at www.redpepperracing.com (search for CF hood).
But be prepared, the 1 piece CF ZC hood costs $500.
duffman868
03-07-2006, 11:07 PM
seeing your car makes me sad i ever sold mine :(
Tarron.shelton
03-10-2006, 09:05 PM
Hey thinks for the info i really appreciate it. It seemed for a minute all the good parts where for a 88 CRX to 91 Crx but thanks for the site.
lxndr
03-10-2006, 10:01 PM
RPR is the best site for 1G CRX/3G Civic owers. Every bit of information you could ever want in regards to these cars can be found there.
85crxzc
03-19-2006, 11:42 PM
are u running with any emission control??? and if not how does ur ecu work without it? i got the same engine in my 85 crx and i ran a 89 emission control box.. sorry for sounding like such a newbie
pimpmcdaddies
03-20-2006, 07:07 PM
less is more...nicely done:smokin:
lxndr
03-21-2006, 12:28 AM
The emissions are controlled by one solenoid, the purge solenoid. The ECU tells this solenoid to open periodically in order to let vapors collected in the charcoal canister flow into the intake system. I simply connected a hose from the fuel tank vapor line directly to the throttle body, and eliminated the solenoid and canister all together.
The other solenoids associated with the '88/'89 motor are the idle-up and resonator solenoids. The EACV serves the same purpouse as the idle-up solenoid so it really isn't needed. The resonator solenoid muffles the sound of the air as it flows through the intake (also not needed).
The ECU will not throw a code by removing these solenoids, and it cleans up alot of the excess wiring in the engine bay.
In the bottom of the '88/'89 Teg fuse box is the ELD (electronic load detector). I removed the ELD from the fuse box and wired it into the wiring harness on the interior side of the firewall. This way I could use the stock CRX fuse box (which I liked better). The only other thing in the fuse box that is needed is the timing jumper, to get around this I installed a switch in the plastic ECU cover and wired it directly to the ECU. Now when I set my timing I reach under the passenger seat and flip a switch instead of installing a jumper in the fuse box.
Hope this helps.
Hope this helps.
85crxzc
03-21-2006, 04:51 PM
cool thanks for the info very helpfull for when i redo my crx..... also u do got a map sensor in that bay somewhere dont u?
lxndr
03-21-2006, 05:38 PM
Yep, it's hidden on the firewall under the intake manifold. I made a bracket that attached to an existing bolt.
85crxzc
03-24-2006, 11:39 AM
sweet man thats a clean setup .. wish mine was that nice
lxndr
07-10-2006, 12:25 AM
More pics!
Here are a few updates:
EDM headlights and corner lights
http://www.redpepperracing.com/gallery/d/149302-2/IMG_2193.JPG
http://www.redpepperracing.com/gallery/d/149299-2/IMG_2183.JPG
http://www.redpepperracing.com/gallery/d/149293-2/IMG_2179.JPG
NRG-CELL 11lb battery with custom made tray
http://www.redpepperracing.com/gallery/d/149311-2/IMG_2176.JPG
Mugen spoiler
http://www.redpepperracing.com/gallery/d/149326-2/IMG_2194.JPG
More here:
http://www.redpepperracing.com/forums/index.php?showtopic=24044&hl=
Mugen spoiler
More here:
DirtyD777
07-11-2006, 11:07 AM
nice 1g :) I love those cars.
Figori
08-12-2006, 07:16 PM
You are my inspiration to keep going on my 1g. With the pay in the Air Force, I'm sure that I'll be able to get that motor in no time. I can almost smell the b18 now...... *drools* I defenitely need to get one of those hoods. I'm pimping the 'no header-panel' look and it's getting old. Props.
lxndr
08-13-2006, 12:25 AM
Hmmm...
Maybe I shouldn't mention that I just picked up a B18. That should to keep me busy this winter, as soon as I decide wether to go all motor with ITB's, or turbo.
Hmmm...
pimpmcdaddies
08-13-2006, 03:53 AM
Hmmm...
What car is going to be the lucky recipient lxndr?
lxndr
08-13-2006, 10:25 PM
It will be going in the car pictured above.
It needs more power! Muahahaha!
lxndr
09-16-2006, 01:43 AM
New wheels! Actually they're old wheels, but newly restored! You'll recognize them from one of my previous posts.
http://www.redpepperracing.com/gallery/d/160284-2/Picture+036.jpg
http://www.redpepperracing.com/gallery/d/160290-2/IMG_2314.JPG
Here are the details:
http://www.redpepperracing.com/forums/index.php?showtopic=28652&hl=
pimpmcdaddies
09-17-2006, 06:35 PM
Nice finish and a labour of love.I did some ford RS wheels years ago and remember spending many hours with wet n dry paper.Like the ghetto lathe too!
Got a set of nice rims on my next years restore (1990 V Tec CRX)which i've been meaning to "borrow" for my black civic..
