Monster iCruze on 04 camry
S2kSi
02-24-2006, 03:25 PM
I need help installing iCruze on camry.
on the instruction, it states "yellow wire need to spiced into constant 12v" so i end up tapping it into yellow wire that's from stereo wire.. but it's not constant, it turns off once the key is placed "off"...
so i was wondering where else can i find this "constant 12v wire"???
Mike Gerber
02-24-2006, 03:42 PM
Get a test light or a DVM and test what wires remain a constant 12 volt source with the engine turned off.
Mike
InstallTech
02-24-2006, 07:20 PM
I'd avoid using stereo wiring and go to the ignition cylinder wiring. That can usually withstand a bit more current. You get too many systems running off the stereo wiring, and you'll end up with blown fuses.
InstallTech
02-24-2006, 07:24 PM
You know....strike that last post. Given what the iCruz is...you shouldn't have any issues wiring it into the radio's wiring. Was thinking of something else. :P
