2000 Eurovan Emmission Questionharley01564 02-22-2006, 10:45 PM I have 3 obd 2 codes that are preventing me from getting another good inspection sticker. They are 0400, 1476, and 1300. What can I do to correct them? veedubmechanic 02-25-2006, 04:51 PM P1476 EVAP Emission Contr.LDP Circ Malfunction Leak detection pump problably failed. Eurovans 00+ have common problems with the charcoal canister and LDP. If its not warranty replace the LDP and Canister. ALso replace the evap purge valve. harley01564 03-19-2006, 10:02 AM About how much should this cost and can I do it myself? I always do my own work. I have replaced the AC compresor,waterpump, brakes, shocks, etc. Is it any more difficult than what I have already done? harley01564 03-30-2006, 09:42 AM Is there a difference between a leak detection pump and a secondary air pump? veedubmechanic 04-02-2006, 08:33 PM yes, the ldp is behind the driver front wheel where the jack point is. Its what pulls a vacuum into the gas tank to see if there is a leak. secondary air pump puts extra air into the exhaust stream to help emissions. Both are easily replaced, parts are expensive though vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
