may day may day!!
jamla
02-22-2006, 07:39 PM
ok dudes, my sl started to vibrate at 65 mph and above (steering wheel)and the whole car at higher speeds.got the wheels balanced,didnt help.then when i went to my mechanic,he told me that the tires (with 10,000 miles only and good tread depth) were wearing out uneven thus the shaking.Also went to the dealership,they checked the engine mounts and came up with nothing.now i finally purchased new tires,but alas the problem persists.I am really pissed and frustrated,any help would be appreciated.some barin storming please..........
Gateway
02-22-2006, 07:50 PM
did you look at the cv joints?
Ralliart 3000gt
02-22-2006, 08:34 PM
Do you have an Aftermarket suspenssion set up. this could cause this if they aren't adjusted properly or are unsuitable for your car......
xXxRocker5150
02-22-2006, 08:54 PM
warped rotors maybe???
youngvr4
02-22-2006, 09:00 PM
good thought but why would that make the whole car shake? especailly on turns at highspeeds
jamla
02-22-2006, 09:02 PM
Got front rotors replaced last year and rear ones sanded,no probs so far. Stock suspension.
SALTSHAKERVR4
02-22-2006, 11:04 PM
U probably puttin new tire with incorrectin alin spec:rolleyes:
When u change tire do alignment same time and rotain tire every 3k mile
3000gt camber and toe is sensitive but u may not sensin. :licka:
2old
02-23-2006, 11:16 AM
In the order or increasing cost if you already changed and balanced the tires:
1. Alignment is off
2. Steering tie rods are worn
3. Ball joints on lower control arms are worn.
1. Alignment is off
