1991 dodge van heater blows hot and cold
Chopper 89
02-21-2006, 08:47 PM
I have a 1991 dodge 250 and when it warms up as long as the idle is up it blows hot air but as soon as the rpm's go down it blows cold air. Also there is a device that when you go up hill it stops blowing on ac and heat i was told its to send power to the engine is there a way to stop this from happening
Stevo2
02-21-2006, 11:48 PM
Sure you don't have a vacuum problem to the dash control?
http://dodgeram.info/tsb/1992/24-06-92.htm
corning_d3
02-22-2006, 12:16 AM
When's the last time the thermostat was changed? That could be a sign of waterpump failure, too. When the impeller blades get worn, they don't pump very well..
Chopper 89
02-22-2006, 08:39 AM
I changed the water pump less than 6 months ago and the thermostat is working I did find a leak last night but when the radiator is full it still blows hot at high RPM's and cold at low RPM's
corning_d3
02-23-2006, 12:03 AM
You may have a heater core on the verge of clogging up. Does your heat gauge move any when this happens?
Chopper 89
02-23-2006, 05:05 AM
The temp. gauge stays the same is it possible that the leak releases enough pressure that it stops water flow
corning_d3
02-23-2006, 01:08 PM
A leak bad enough to lose heat would be a gusher. Although, if the cooling system lost pressure, the coolant would boil easier, allowing air into the system.
