won't start after every fill upthomas12 02-21-2006, 03:28 PM I have to start all over. my car stalls after each and every fill up at the gas station. Other times run good and start without problem. Does anybody hear about someting like this. I read the codes and there is one P0441. where to start? Please help. veedubmechanic 02-21-2006, 09:43 PM your filling up gas too far and its putting gas into the evap lines flooding thecharcoal canister and evap purge valve. replace your evap purge valve and it should help alot Will12 02-22-2006, 12:59 PM 99 passat 1.8t. I was filling up and I placed a gas cap under the lever, so I can warm up in car, and the nozzle did not stop, and gas just spilled all over the ground--it happened twice. Perhaps, the purge valve is taking some of the pressure? thomas12 02-22-2006, 03:24 PM I usually don't fill up to the end especially when the prices of the gas fluctuate so much. It does't matter how much gas i put the problem accures. I never overfilled the tank. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
