Help : 99' Tacoma 5 Lug Fit ????????kool7 02-21-2006, 02:27 PM HI, is there any other brand ( Nissan , ford, Honda ? ) rims that will fit my 99' Tacoma ( 2wd) , 5 lug truck ? thanks for your time and help... joe las vegas , nv. Flash75 02-21-2006, 04:01 PM It's 114.3 x 5 bolt pattern, very common. You may need to be careful about offset. You can search here for something to fit. http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm Clifton kool7 02-21-2006, 06:26 PM thanks Clifton .what's is the offset ? ............ joe Flash75 02-21-2006, 09:39 PM This link explains offset with a drawing. It's the distance the inside wheel mounting surface is from the center line of the wheel. http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101 Note the link in my first response has the offset listed in the right column. They are listed as H high M medium L low. You should try to stay close to the original offset for best handling and less stress on the chassis components when changing wheels. Clifton vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
