Changing the corner headlighthighprofilenyc 02-20-2006, 11:57 AM I have a 96 Camry and I am having a hard time getting the corner headlight out to change the bulb. The manual basically say unscrew a screw and it pulls right out. I dont want to force it and break it. Am I missing a step in this process? Mike Gerber 02-20-2006, 06:18 PM I think the manual is correct, if it is like the earlier generation 3's. I have a 94. You have to give it a tug straight forward. It probably would be better to do this in warmer weather; less chance of breaking anything. When I got mine out, I put some grease down in the hole (it will become obvious once the lens is removed) to facilitate getting it out again in the future. Mike highprofilenyc 02-20-2006, 09:09 PM Thanks MIke, I carefully pushed the light forward and it popped out. I just didnt want to damage the light. thanks again Mike Gerber 02-21-2006, 01:11 AM Thanks MIke, I carefully pushed the light forward and it popped out. I just didnt want to damage the light. thanks again You're welcome. Don't forget about putting a dab of grease in that hole. It will make it easier to remove the next time. Mike vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
