95 camaro 3.4L HELP WITH OVERHEAT!tattoowayne 02-19-2006, 11:14 PM first time posting so, hello all. i have a 95 camaro 3.4L ( i know, i wish it was a v8 too) i have replaced both coolant temp sensors, the water pump, radiator cap, and varios other tune up items and the car runs like a dream. however the temp guage climbs to max almost immediately and stays there, but the car is actually running at normal temp. the guy that changed the temp sensors said the one on the driver side of the engine had a cracked wire harness and could be the problem, but after closer inspection it looks fine. unfortunately i noticed he did not use teflon tape on the sensor threads nor did he screw them all the way in. could this be the problem or do i have to shell out the 80 bucks for the new harness. also fans work fine and as i said the temp is normal but the guage says otherwise. PLEASE HELP!. Rally Sport 02-19-2006, 11:16 PM Hey, welcome to AF! Glad to have you with us. Btw just a question, but you HAVE replaced the thermostat, right? tattoowayne 02-20-2006, 12:12 AM yeah stupid me. i forgot to write that. yeah the temp sensors and the thermostat. pump works as well as fans. car runs great just temp guage is maxed out. 666_speed 02-20-2006, 12:55 AM my 94 3.4l did the same thing, didnt have it long enough to get it fixed tho...someone slashed my tires and i had a blow out and wrecked it.....but good luck! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
