Toyota Camry LE 1998 remote programming
molmik0510
02-19-2006, 10:19 PM
I've lost one of my key for this car. To save some money I looked around and found similar remote on eBay. FCC ID ELVAT 6B and FCC ID ELVATOE, this is the new replacement for 6B. I've bought the instructions for programming, after found on internet as well.:banghead:
I know there are 2 types of security system built into these cars.GQ43VT7T is for the factory remote system and uses the jumping 2 pins on mirror adjusment switch. The other is the RS3000/VIP system, which uses a different programming, closing opening doors etc.
http://toyotasecurity.buypartsonline.biz/
None of them worked for me so far. :banghead:
I've found the main security module, Part number 00014-S0200.
Please help me!!!!!:disappoin
I wanted to save money because the dealer asking $40 for programming.:2cents:
Thanks!
camry98le
02-20-2006, 10:36 AM
Here you go. Hope this helps.
PROGRAMMING ADDITIONAL or REPLACEMENT TRANSMITTERS
Each SECURIKEY+ system can be operated by up to four (4) different
SECURIKEY+ transmitters. The system is supplied from the factory with two
(2) transmitters included, and additional transmitters are available through
parts distribution. Any new or replacement transmitters will need to be
programmed to the main control module before they will activate the system.
The SECURIKEY+ main control module uses a six (6) channel radio frequency
receiver; each channel controlling a different function of the SECURIKEY+
system. Each transmitter button can be programmed to only one of the
receiver channels (e.g., the GREEN button cannot be programmed to operate
the headlight feature and remote start option; it can operate only one or
the other feature). The following is a list of each receiver channel, and
the function of each channel.
CHANNEL # FEATURE CONTROLLED BY THIS CHANNEL
1 Lock
2 Unlock
3 Trunk Release (optional kit required; not available on all models)
4 30 second headlight activation (only if required by GREEN button)
5 Remote panic (only if required by GREEN button instead of LOCK
button)
6 Remote start (optional kit required; not available on all models)
To program new or additional transmitters, or when adding options to
existing SECURIKEY+ transmitters, follow the step by step programming
instructions found below. When programming, it is important to complete each
step of the procedure within 15 seconds, or the system will terminate the
programming mode. If this happens, simply start again.
Be sure that the SECURIKEY+ system is disarmed, and the lighted valet switch
is in the off (out) position before you begin.
Turn the vehicle's ignition key to the on position.
Press then release the L.E.D. valet switch 6 times.
CHANNEL 1: LOCK & Panic Feature Horn Chirps 1 Time L.E.D. Flashes 1 Time
To program the LOCK button on the transmitter, press and hold the LOCK
button until the vehicle's horn sounds one loud chirp. Repeat this for all
transmitters that need the LOCK button programmed (up to four transmitters).
After the LOCK button on all transmitters have been programmed, press and
release the L.E.D. valet switch 2 times to advance to the next receiver
channel.
CHANNEL 2: UNLOCK Feature Horn Chirps 2 Times L.E.D. Flashes 2 Times
To program the UNLOCK button on the transmitter, press and hold the UNLOCK
transmitters that need the UNLOCK button programmed (up to four
transmitters).
After the UNLOCK button on all transmitters have been programmed, press and
channel.
CHANNEL 3: TRUNK RELEASE Option Horn Chirps 3 Times L.E.D. Flashes 3
Times
To program the TRUNK RELEASE option on the transmitter, press and hold the
GREEN option button until the vehicle's horn sounds one loud chirp. Repeat
this for all transmitters that need the GREEN option button programmed (up
After the TRUNK RELEASE button on all transmitters have been programmed,
press and release the L.E.D. valet switch 2 times to advance to the next
receiver channel.
CHANNEL 4: 30 SECOND HEADLIGHT Feature Horn Chirps 4 Times L.E.D.
Flashes 4 Times
To program the HEADLIGHT option on the transmitter, press and hold the GREEN
option button until the vehicle's horn sounds one loud chirp. Repeat this
for all transmitters that need the GREEN option button programmed (up to
four transmitters).
After the HEADLIGHT button on all transmitters have been programmed, press
and release the L.E.D. valet switch 2 times to advance to the next receiver
channel.
CHANNEL 5: Separate PANIC Button Feature Horn Chirps 5 Times L.E.D.
Flashes 5 Times
To program the PANIC option on the transmitter, press and hold the GREEN
four transmitters).
After the PANIC button on all transmitters have been programmed, press and
channel.
CHANNEL 6: REMOTE START Feature Horn Chirps 6 Times L.E.D. Flashes 6
Times
To program the REMOTE START option on the transmitter, press and hold the
After the REMOTE START button on all transmitters have been programmed,
press and release the L.E.D. valet switch 2 times to advance to terminate
programming mode, or simply turn the ignition key to the off position to
terminate the transmitter programming mode.
PROGRAMMING THE SELECTABLE FEATURES
The SECURIKEY+ system offers a number of selectable features that can be
changed, allowing you to custom fit the system to your customer. The
following is a list of the features that are selectable and can be changed
using the valet switch and any transmitter that is programmed to the system
installed in the vehicle.
FEATURE # FUNCTION 1 CHIRP 2 CHIRPS
1 Headlights on for 20 seconds during disarm ON or OFF
2 Headlights on for 20 seconds during arm ON or OFF
3 Automatic ignition controlled door lock ON or OFF
4 Automatic ignition controlled door unlock ON or OFF
5 Auto unlock driver's door only or all doors Driver's door or
All doors
6 Active or Passive arming Passive or Active
7 Active or Passive door locks Passive or Active
8 Trunk release output - 1 second or latched 1 second or
Latched
9 Panic on lock button or option button Option or Lock
10 Trunk Release Hold - 1 second or 2 presses Hold 1 Sec or
2 Times
To change the selection of any of these features, follow the step by step
programming procedures, and do not allow more then 15 seconds to pass
between any two steps or the system will terminate the programming mode.
There is no need to complete the entire programming sequence. After the
appropriate features have been changed, simply turn the ignition key off to
Immediately turn the ignition key off then back on.
FEATURE 1 LED Flashes 1 Time
1 Chirp = Headlights ON During Disarm Horn Chirps either 1 or 2 Times
2 Chirps = Headlights OFF During Disarm
To change the selection, press and release the lock button on the
transmitter, which will be indicated by the appropriate 1 or 2 chirp signal
from the horn. If you do not want to change this feature, simply press and
release the L.E.D. valet switch 2 times to advance to programmable feature
number 2.
FEATURE 2 LED Flashes 2 Times
1 Chirp = Headlights ON During Arm Horn Chirps either 1 or 2 Times
2 Chirps = Headlights OFF During Arm
number 3.
FEATURE 3 LED Flashes 3 Times
1 Chirp = Ignition controlled door locks ON Horn Chirps either 1 or 2
Times
2 Chirps = Ignition controlled door locks OFF
number 4.
FEATURE 4 LED Flashes 4 Times
1 Chirp = Ignition controlled unlock ON Horn Chirps either 1 or 2 Times
2 Chirps = Ignition controlled unlock OFF
To change the selection, press the lock button on the transmitter, which
will be indicated by the appropriate 1 or 2 chirp signal from the horn. If
you do not want to change this feature, simply press and release the L.E.D.
valet switch 2 times to advance to programmable feature number 5.
FEATURE 5 LED Flashes 5 Times
1 Chirp = Ignition controlled unlock DRIVER'S DOOR Horn Chirps either 1
or 2 Times
2 Chirps = Ignition controlled unlock ALL DOORS
valet switch 2 times to advance to programmable feature number 6.
FEATURE 6 LED Flashes 6 Times
1 Chirp = PASSIVE ARMING (Automatic Arming) Horn Chirps either 1 or 2
Times
2 Chirps = ACTIVE ARMING (Arm by Remote Only)
valet switch 2 times to advance to programmable feature number 7.
FEATURE 7 LED Flashes 7 Times
1 Chirp = PASSIVE DOOR LOCKS Horn Chirps either 1 or 2 Times
2 Chirps = ACTIVE DOOR LOCKS
valet switch 2 times to advance to programmable feature number 8.
FEATURE 8 Do not change this feature selection. It should be left in the
factory preset (1 chirp) mode. Press and release the L.E.D. valet switch 2
times to advance to programmable feature 9.
FEATURE 9 LED Flashes 9 Times
1 Chirp = Remote Panic / GREEN transmitter button Horn Chirps either 1 or
2 Times
2 Chirps = Remote Panic / LOCK transmitter button
valet switch 2 times to advance to programmable feature number 10.
FEATURE 10 LED Flashes 10 Times
1 Chirp = Trunk Release HOLD GREEN BUTTON 1 SECOND Horn Chirps either 1
or 2 Times
2 Chirps = Trunk Release PRESS GREEN BUTTON 2 TIMES
valet switch 2 times to exit the programming mode.
molmik0510
02-21-2006, 06:52 PM
I've tried it and works. However... I made a mistake.
First of all, when I press and release the L.E.D. valet switch after the 4th push the horn chirps 2 times and the L.E.D. flashes 2 times. Basically nothing else happens but you can go through the program steps by pushing twice the switch. So I’ve ignored this and continued pushing the switch 2 more times, until the sum of 6, and started the programming. I did not watch however, how many times the L.E.D. flashed so I programmed the remote lock button to turn the headlight on for 30 min. After that I could not reprogram the lock button to the right way. Is there any way to reset the alarm system to reprogram the remote the right way?
I'm so sorry but this happened.:uhoh:file:///C:/DOCUME%7E1/molmik/LOCALS%7E1/Temp/msohtml1/01/clip_image001.gif
Thanks for your help!
camry98le
02-21-2006, 10:27 PM
First of all, I am happy for you that you got it to work. congrats. I still remember the first time when I had my sucess, it feels so good. I was so pissed with the manager at the dealership that I would provide all sequence for free, no matter what kind of toyota remote you have. Here I am. :)
secondly, what you can try is to exit all programming mode and reprogram the remote. I am sick at the moment and do not have much time to look at the sequence. But anyways, if that doesn't work, you just have to erase all the remote from your ecu and start from scratch(reprogram). let me know if you still have problems.
molmik0510
02-22-2006, 12:28 AM
Thank you for answering so fast and I wish you fast recovery!
Can you tell me how I can erase all the remote from the ecu?
camry98le
02-23-2006, 10:10 AM
you do not need to erase all the remote for the time being. Just start the programming sequence again. Just like how you started. Read through the instruction and be prepared to reset your setting. That should do the trick. Good luck. Sorry, I wasn't around yesterday. I was so weak that I could not do anything. good luck. PM me if you need any more help.
molmik0510
02-23-2006, 10:46 AM
OK I'll try it again. I tried yesterday, it did not work but I did not give to much time to it because the horn is so loud and everybody was allert. :)
I'll let you know. Thanks again! I hope you are better by now!
molmik0510
molmik0510
02-23-2006, 10:58 PM
Well, I've tried it. The new remote dose nothing. I've got an other remote and I could program only partially. Just the lock button could be programmed. Basically, I do not know how many keys have been programmed for this car because I bought it as a used one. So I thing the reset would be the only hope to start everything from scratch.
By the way, the program mode is turn on by 4 press and release, or may be less because I've got immediately into the channel 2 programming mode.
Can you tell me how I can reset the main module?
Thanks again for being so nice and helpful. I hope I can return this somehow.
molmik0510
03-15-2006, 01:45 PM
I've solved my problem, finally. I've called up Gulf State Toyota Online Technical Service and they helped me out.
To erase keyless remote you can do it separately. So you do not need to clear every remote from the main module you can do it individually.
Method:
Go to program mode: ignition key on, push red switch 6 times (3 in and out cycle) 1 short beep.
Push and hold lock and green bottom simultaneously, long beep. Do it 4 times...... you deleted the lock key from main module
push red switch twice (one in and out cycle) 2 short beeps.
Push and hold unlock and green bottom simultaneously, long beep. Do it 4 times...... you deleted the unlock key from main module
push red switch twice (one in and out cycle) 3 short beeps.
Push and hold lock and unlock bottom simultaneously, long beep. Do it 4 times...... you deleted the green key from main module
Turn the ignition key off ... Exiting program mode. Long beep and a short one.
Reprogram your remote as written in the manual:
1. Push lock key... long beep means the module accepted it
2. Push red switch twice (one in and out cycle) 2 short beeps.
3. Push unlock key .. long beep means the module accepted it
4. Push red switch twice (one in and out cycle) 3 short beeps.
5. Push green key .. long beep means the module accepted it
6. Turn the ignition key off... exiting program mode.. long and a short beep.
Now you can try to push lock key... it should work fine.
I hope I can help other people by this! By the way the people of the Gulf Toyota Dealership are very friendly and helpfully. They will help anybody out for sure!
desmondfox
06-15-2006, 11:10 AM
My dealer installed remote is FCC ELVAT5G . I purchased the car used with only one remote and no instructions whatsoever concerning the security system.
This is what my existing remote looks like:
http://www.autotechs.com/items/item391.htm
This is the spare/replacement I have purchased:
http://www.autotechs.com/items/item224.htm
Just wanted to confirm with this thread's contributors whether these remotes are programmable with the instructions provided above in molmik0510 and camry98le 's posts.
Thanks,
DFox.
coinho
09-11-2006, 08:48 PM
Hi all,
I didn't know my car had the alarm system (I bought used car without the remote control), I unpluged the Battery and when I tried to put it back the arlam when off. Is there a way to reset it without the remote control?
somick
09-12-2006, 05:27 PM
Hi all,
In my 1999 Accord the aftermarket alarm has so called valey switch. They taped it to the fuses harness. In order to disable the alarm I have to put ignition key into on (car not running) and hold valey switch pushed untill the siren stops sounding. My son's car has just a tiny toggle switch at the knee level.
Try to look around for the alarm module. Usualy a black or clear box.
If worst comes the worst disconnect the siren.
Good luck!
Sam
fuknremotes
06-20-2008, 05:51 PM
omg!~~!!!
My stupid alarm (same one obviously) killed my battery. When I bought the car used (also) I was told not to mess with the remote because it had to be re-set at the dealer. I took it to a dealer in Carlsbad, Ca and they said they couldn't do it0 LAZY BASTARDS! Thank God I found your blog because the damn thing started going off a month or so ago and my husband pulled the fuse to the horn/alarm and somehow it shorted the alarm anyway and my headlights would flash even though the car would not start and my battery needs to be replaced now. Sh*t part is the alarm started "working" or going off randomly anyway but my car was still broken into and ALL my jewelry was stolen out of it the nighr before we moved!! GRRRR this damn alarm is useless! Thanks SO MUCH for the instructions- FREE ones at that!:banghead:
Method:
hard2000
07-07-2008, 12:34 PM
where is the valet switch for toyota Camry??
fuknremotes
07-07-2008, 08:25 PM
:banghead: where is the valet switch for toyota Camry??
well, mine has a little red button to the left of the steering wheel.... it pushes in and out and before the battery was totally drained i had to do exactly what the other person said and hold it in for like 3 seconds with the key in the "on" position.... good luck man i just had the auto body shop yank the damn thing out since my car had been broken into it never functioned properly anyhow- best of luck!
heyyo302
07-16-2008, 11:30 AM
When you open the panel you will see a black box attached to the upper panel with three connectors coming into it from left. The front end(facing driver) was held by a zip tie to a connector so I just cut it and tilted it down which reveals a small green program switch. From here the instructions are the same from this 4runner example http://www.4runners.org/articles/rs3000/ (http://www.4runners.org/articles/rs3000/)
fuknremotes
07-16-2008, 07:43 PM
to the left of the steering wheel- little red light on button. fukn retarded if u ask me
