update for 97 grand am troubledampontiac 02-19-2006, 09:07 PM Well i was able to tell that the oil was draining outta the passenger side of the motor on the bottom. Put four quarts in and started the vehicle and oil was draining out right away. i wasn't able to put the car on jackstands and take a look so yeah thats about all i have for an update. thank you to all that look and reply!!!! xeroinfinity 02-20-2006, 11:15 AM Well i was able to tell that the oil was draining outta the passenger side of the motor on the bottom. Put four quarts in and started the vehicle and oil was draining out right away. i wasn't able to put the car on jackstands and take a look so yeah thats about all i have for an update. thank you to all that look and reply!!!! So what all was happening to your GA? If the oils pouring out, thats not goood. You thinking somethings cracked or what? If Your crank shaft seals shot it will leak like that, so will the rear main seal(back of motor). vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
