HELP I keep losing my power steering!
View Full Version : HELP I keep losing my power steering! HELP I keep losing my power steering! dawnze 02-19-2006, 12:16 PM Please Help!!!!!!!!!!!!!! tafkah 02-20-2006, 04:35 PM Does it do that in dry and in wet weather? My 94 villager does the same when i drive through lots of water. According to the dealer, there's nothing to do about my prob. IH8SPM 02-28-2006, 09:32 PM It sounds like a fluke and the fact you are a girl has nothing to do with it. First you should have known to check the basics. Yes fluid is one but did you check your pullies and belts that may have slipped due to some antifreez leak or spill of any other kind including water from the ground. The van looks to be hight of the ground but the engine is not and neither are the belts. I would be aware of my speed and road conditions at all times and when and if it ever happens again I would start my check list. You may also experienced a power loss if you where at highway speed you may have not even noticed the engine stall. dawnze 03-04-2006, 12:47 AM The only weather condition was it was cold. All the fluids are up to snuff, belts tight and no antifreeze smell nor leak no puddles on garage floor. Since I first wrote it has done it several more times. And yet no one is able to tell what is wrong. Flay 03-04-2006, 01:20 PM The only weather condition was it was cold. All the fluids are up to snuff, belts tight and no antifreeze smell nor leak no puddles on garage floor. Since I first wrote it has done it several more times. And yet no one is able to tell what is wrong. It could be the valve diverter body in the steering rack. When you turn the steering wheel, a tiny set of valves in the rack direct the PS fluid one way or the other, depending on direction of turn. If a valve sticks then you lose PS assistance and this sounds like your symptoms. Happened on my Ford Aerostar that's why I know about this. Stevo2 03-04-2006, 02:24 PM Replace the steering rack. C. Cleve 03-20-2006, 06:05 AM Hi, I would try FRESH steering fluid before anything else,,,May help,,, Clay.. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
