Aftermarket plug wires and stock heat shieldspenguinland 02-18-2006, 07:42 PM I bought a set of Taylor Spiro-Pro cables and found that the fancy boots won't fit in the stock heat shield tubes. Has anyone had a problem leaving the heat shields off? MT-2500 02-18-2006, 08:10 PM You would be better off using OEM type plug wires with the heat shieldswill work on. They put them on there for a good reason not decoration. MT BlenderWizard 02-21-2006, 02:36 PM I used some Accel 8mm wires on my truck and the shields fit fine vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
