roof rack removalBlazinMlew 02-18-2006, 07:21 PM Just wondering if anyone has done this. I am wanting to do mine but not sure how much I will have to pay the body shop to fill in the holes. Tha covering on the rack is chipping anyway and to be honest I will never use it and just like that clean look. Thank for the help muzzy1maniac 02-18-2006, 09:24 PM Just wondering if anyone has done this. I am wanting to do mine but not sure how much I will have to pay the body shop to fill in the holes. Tha covering on the rack is chipping anyway and to be honest I will never use it and just like that clean look. Thank for the help You might be able to match the threads of the oem bolts and get some shorter ones to fill the holes. Haven't done it so I'm not sure. OverBoardProject 02-19-2006, 01:36 AM I don't know about your year, but the first generations have raised ribs under all the slats that would look just as ugly (If your tall enough to see the roof) BlazinMlew 02-19-2006, 03:33 AM I don't know about your year, but the first generations have raised ribs under all the slats that would look just as ugly (If your tall enough to see the roof) Yeah I have those raised ribs as well but I can live with those more so than the god-awful black rack.:disappoin gman2153 02-19-2006, 04:05 AM Why don't you just put another coat of black paint on it? rlith 02-19-2006, 07:18 AM If you're gonna remove it, not only have the holes filled in, but have the roof smoothed out as well. IMO having the ribs there looks worse than no roofrack. If you want to redo the paint on the roof rack, simply give it a light wet sanding with 300 grit, then 800 grit, then use primer, then clear. I did that to mine and you can't tell it from stock. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
