96 blazer engine replacement
Google
Web AF
redtoygts
02-17-2006, 06:44 PM
Sorry for the dumb question but I'm replacing the engine in my blazer and I am having difficulty reaching the top left bell housing to engine bolt. The trans-tunnel is preventing me from getting in there. Is there an easy way to remove this bolt with out removing the engine and transmission as a whole? Can I just lower the transmission to gain clearance? Any imput would be very helpful as it is the only thing holding this project up.
maxwedge
02-17-2006, 07:28 PM
Long extension, flex socket and lower the trans will help of course.
Rick Norwood
02-17-2006, 08:03 PM
Usually an 18"-24" extension works on Bell housing bolts.
herkyhawki
02-17-2006, 10:24 PM
It can be reached from the top with a box end wrench. If you remove the intake first.
Another way is to drill through the floor board from inside. The bolt is directly behind the gas pedal. Measure 3 times, drill once. If you first drill with a small bit, you can see if you are in right spot before making it bigger.
MT-2500
02-17-2006, 10:36 PM
That one usually is a piece of cake older Blazers and S-10 are the hard ones.
If all else fails you can do it like a ford.
http://flatratetech.com/images/nav_how_to.htm
MT
Google
Web AF
