96 Blazer Dead Battery All new
Google
Web AF
Rick1488
02-16-2006, 11:36 PM
Hello,
I went to start my truck yesterday and the battery was dead jumped it with a quick starter and it fired right up and was geting about 15volts from the gauge, but it died again after I drove it about 10 miles shut the engine of for like 2 minutes and was dead so, I changed the battery and everything seem to be fine, but it died again while at work so I moved on to a new alternator and I thought everything was fine, but I just tried to go to a friends house and the damn things is dead again.. I checked all the cables on the battery and alternator and all is tight, but it is dead!!
What is the problem??
96 Blazer V6 4.3 Vortec 100k miles 2DR 2WD
:banghead:
Thanks!!
Teal95Jimmy
02-17-2006, 12:47 AM
Try charging your battery up and leave it unhooked from the truck during the night. Hook it back up in the morning and see if still has a charge, if not its the battery. If it holds a charge there is a draw coming from somewhere within system
muddog321
02-17-2006, 05:18 AM
Check the battery voltage when the Blazer if off. Should be about 12.6 V. If you loose a cell it drops 2.1 V per. All auto stores will also do this for you and run a load test. Check that before you start a search for cables and shorts. In hot southern states heat kills batteries in 2-3 years.
the87hyper
02-17-2006, 11:41 AM
A "Bad" starter will cause the battery to drain if its not dis-engaging from the bendix (i think). We had a old 72 Ford F600 box truck and it was eating batteries and alternators like crazy. Turned out the starter was leaving a circuit open all the time and draining the batt. good luck
spano
02-17-2006, 04:17 PM
Start disconnecting parts, sounds like fun huh? I found I had a draw coming from my power seat and was killing my battery and yes I had a new batt and new 100amp Alt. I also see a major draw when I have the rear defroster on in the morning, when I stop I go down to 12 V.
blazee
02-17-2006, 04:35 PM
Did you completely recharge the new battery before you hooked up the new alternator? If not, that could be your problem. The alternator won't charge right when connected to a partially dead battery.
Rick1488
02-17-2006, 08:04 PM
Ok I unhooked the battery and charged it until my charger said full then I took the new battery to autozone they said it was fully charged so I hooked it back up and drove it to local mechainic he tested the alternator, battery and starter and said their all good. I thought everything was fine so I drove it home stopped at the video store was in there about 10 minutes came out and the battery was dead. I brought my tester with and it showed the battery as 0 volts dead! I unhooked all accessories, but something is eatting the battery all to hell!!!
Blazee,I charged the battery fully before installing..
Thanks, Rick
mike2004tct
02-18-2006, 01:11 AM
..... I thought everything was fine so I drove it home stopped at the video store was in there about 10 minutes came out and the battery was dead. I brought my tester with and it showed the battery as 0 volts dead! I unhooked all accessories, but something is eatting the battery all to hell!!!
Thanks, Rick
Exchange it for another battery.
Just because it's new, doesn't mean it can't take a dump.
(Who knows how long it sat on the shelf?)
The only other thing I would have guessed was a bad Cable (break somewhere in the cable itself). But with 0 volts, you either put the positive to the frame and toasted the battery (and everything else electrical in the truck), or you got numerous bad cells in the battery.
rlith
02-18-2006, 07:48 AM
I'd also like to point out that half the time those testers that autozone/advance uses don't always read right. The fact that you charged the battery and it died after 10 minutes may mean it's not getting a charge. If you do replace the battery and it dies, more than likely the voltage regulator inside the alternator is bad.
Rick1488
02-18-2006, 10:28 PM
Alright I returned the battery for a new one and the truck seems to be keeping the charge... It's been 4hrs sense install and it started right up when I just went out there to test it. I'll let you know after work in the morning if it starts...
Thanks!!
rlith
02-19-2006, 07:23 AM
Thanks!!
With the car off, leave your headlights on for 10 mins. Any battery should be able to handle that and still start. If it doesn't it's not getting a charge...(dim lights at night will also show this) Good luck! I hope just the battery change solved your issue.
Jon Teeter
03-21-2006, 01:03 AM
I have bought batteries in the past from Autozone that were no good
Google
Web AF
