cranks wont start
Google
Web AF
blazin911
02-16-2006, 08:56 AM
i have installed everything from the fuel pump to the whole intake and cpi unit timing chain ignition etc...im not getting fuel to the engine but ihave pressure the valve 64psi everything from the intake is new nut kit and cpi unit plus gaskets sensors and so forth someone help
ps if i had the red and blue wiires to the plug on the cpi crossed would that cause a problem
billibong
02-16-2006, 09:05 AM
Need more info about the truck - what year, what engine, anything that has been done lately?
2kTrailBlazer
02-16-2006, 09:26 AM
did u check the cap? blazers have big problems with the cap going bad. the cap is a plastic design and the leads are ran close together and sometimes arc. please reply with what you find out
unh_fat_j
02-16-2006, 10:26 AM
97 blazer: v6: 100,000 mi: 4wd: 2 dr
For about 3 years I have had the intermittent problem of my Blazers engine quitting while driving (dropping to 0 RPM, no engine noise) then it will sometime kick back in.. sometimes it will not. Most of the time I can just shut the car off and fire it back up again. It will always crank fine, like the original poster stated, but sometimes it will not start. I've had it happen where I leave the car for 20 minutes, come back and it will then start fine.
The check engine light does not come on due to this problem. The lights and all electrical will continue working even after the engine quits.
New wires, cap and rotor, plugs, ignition, among other things have been installed since the problem started.
2kTrailBlazer
02-16-2006, 10:34 AM
later model vehichles have a fuel saftey switch , so that at sudden stops or flips the fuel pump turns off...maybe something is wrong with that system? that would be my guess
unh_fat_j
02-16-2006, 10:45 AM
Thanks for the reply. Most of the time it happens while I am cruising however. It will occur when the engine is hot or cold as well.
I also want to note that I have replaced the fuel filter... as I noticed that this seems to be a common suggestion to any sort of stalling issues.
unh_fat_j
02-16-2006, 10:47 AM
Sorry, I should have digested your post a little longer before replying. I will check out the fuel safety switch. Thanks
2kTrailBlazer
02-16-2006, 10:52 AM
not a problem, send me an email when you find out what it is.
blazes9395
02-16-2006, 04:55 PM
An intermitent stalling problem can be traced to a faulty ignition system, specifically either the crankshaft sensor(GM had all kinds of problems with early model crankshaft sensors), or the ignition module. There are diagnostic flow charts for this system. Also (very important), check both connections at the crankshaft sensor, and at the ignition module. A hint to virtually eliminate a connection problem is to slightly bend the metal contact/connection points inside the sensor(s). When you plug it in, because its a little bent, it will make a strong and positive connection to the harness connector - connection problems solved.
If it stalls and restarts again, its most likely a connection problem at one of these sensors. To check for this, start the truck up (its usually a good idea to do this when the truck is warm, heat expands things, connectors are no exception.) wiggle the connector at the ignition module and at the crankshaft sensor. If it stalls, or misses, slightly stops and resumes running - you have found your problem.
unh_fat_j, if you have no RPM reference, and it stalls and restarts, take a look at the crankshaft sensor first AND the connection.
Usually no codes will come up with this problem, so thats why its so hard to pinpoint, because when you go to test this system, it check out ok.
mike2004tct
02-16-2006, 05:04 PM
Classic symptoms of the dreaded Ignition Switch module.
blazee
02-16-2006, 08:29 PM
blazin911, feel free to start another thread if you need more help. unh_fat_j pissed all over yours.
unh_fat_j, in the future, please start your own thread when you need help.
slreno1217
02-16-2006, 09:01 PM
cam shaft sensor , or the piock up coil as some call it.. mine was doing the same exact thing. if the pc senses no spark it wont let fuel go. 10 bucks to a doughnut cam sensor or crank sensor.
cam sensor is under the rotor button in the dist. assembly
unh_fat_j
02-16-2006, 10:04 PM
Ended up being the crankshaft sensor. Thanks to everyone for your help and suggestions.
Sorry, 1st posting... will start a new thread in the future.
Google
Web AF
