95 Blazer keyless entrymadavis205 02-15-2006, 03:13 PM i just purchased a 95 blazer and i need to reprogram the keyless entry can anybody tell me how to do this Thanks Mark Jeremy Fitch 02-15-2006, 03:14 PM PROGRAMMING INSTRUCTIONS All Extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters. Transmitter Programming: 1) With the driver door closed, hold down the power UNLOCK button on the door panel. 2) Turn the ignition switch to the ON position. 3) Turn the ignition switch to the OFF position. 4) Turn the ignition switch to the ON position. 5) Turn the ignition switch to the OFF position. 6) Release the power unlock button on the door panel. The remote control door lock receiver will respond by cycling the locks to indicate the receiver is in the programming mode. 7) Hold down the lock and unlock button on the transmitter for about 30 seconds. The locks will again cycle to confirm programming. - REPEAT step 7 for each additional transmitter. 8) Turn the ignition to the ON position in order to exit the transmitter programming mode. blazee 02-15-2006, 03:20 PM If that doesn't work try this: http://www.automotiveforums.com/vbulletin/showthread.php?t=464777 madavis205 02-15-2006, 03:36 PM i tried to enter the programming mode and it would not go blazee 02-15-2006, 03:41 PM Did you try the method described in the link that I posted. It worked for the other 95 owners. Jeremy Fitch 02-15-2006, 03:45 PM The method I posted may only work for 96+ models. madavis205 02-15-2006, 03:49 PM i got it to enter the programming mode using the way blazee posted but i think i have a bad transmittor wont program thanks for the info Mark Onblsht 02-20-2006, 11:12 PM Are you sure you are using the correct remote for your Blazer? madavis205 02-21-2006, 08:29 AM according to the dealership i have the correct remote nickledimed 02-21-2006, 04:41 PM cheap remote?.....my ars...40 bucks for something that has less technology than my tv remote...sheeesh vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
