Installing New Speakers in 96 Z34 Montejoshjweber 02-15-2006, 03:12 PM How do I do it? Does anyone know of any free sites with exact instructions? I actually just need to know how to remove the door panels to pop in the two speakers in the doors, and how do I get the carpet peice up in the back to get at the 6 X 9's in the back????? Thanks a lot -Josh dwalmop 02-21-2006, 10:00 AM The carpet piece essentially slides out with the removal of the rear seat. To remove the seat, there are 2 bolts (maybe nuts) near the floor (just feel for them you can't miss them). Remove them and pull the seat bottom out. Then I believe there are two bolts on the seat back which are accessable when you fold down the rear seats for trunk access. Once you have those out, lift on the seat, remove the seatbelts from the slide clip things, and remove the rear seat back. You should be able to slide the rear deck cover off now. Then you can see the 4 screws that hold each speaker in. The fronts come out upon removing the door panel, which is done by removing the plastic trim over and around the handle to locate a screw, then there are a few more screws you can see without removing anything. Take all those screws out, then from the bottom, "peel" the door panel away from the door. It is simply snapped on. Once those are you lift on the panel to release it from the top. You may have some mirror cables and stuff to play with but it's pretty intuitive. I'm not sure, but to simply replace the 5 1/4's in the front you may just have to remove the grill part from the door panel with by prying it off with a screwdriver. Try this first before you go through all the work or removing the entire door panel. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
