DRL turn off
Google
Web AF
5wood
02-14-2006, 11:12 PM
Does anyone know if or how the DayTime Running Lamps can be turned off of an '05 Equinox?
Thanks.
BFSID23
04-17-2006, 11:09 PM
https://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gif
https://www.mygmlink.com/images/US/en/chevrolet/chv_ttl_vehiclefaq.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gif2005 Equinoxhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_mileage2.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_odometer0.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_odometer2.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_odometer1.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_odometer7.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_odometer5.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_odometer0.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_btn_editsmall.gif (javascript:newEditWindow('editmile?vehid=1509034&subaction=vehfaq:vehid~1509034&actionpage=3_4_3','chv','21750')) https://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifWe've collected and answered vehicle-specific questions you might have about your Chevrolet. https://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifHow do I turn off the Daytime Running Lamps when necessary?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#0)Where can I find information about usingOnStar ?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#1)The direction of the compass on my Equinox doesn't seem to be correct. Should I calibrate it?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#2)The compass in the mirror of my new Equinox displays CAL. What should I do?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#3)The Service Engine Soon light is flashing in my Equinox. What does this indicate?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#4)Where are the fuses located in my Equinox?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#5)Why won't cruise control work at low speeds?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#6)How do I set the clock on my Equinox?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#7)Why does the sound of my engine change when I turn on the Defrost?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#8)How do I fold or recline the rear seats?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#9)What should I know about the Passlock theft-deterrent system?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#10)I forgot to put on my gas cap and the Service Engine Soon light is on steady. How can I turn the light off?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#11)How often should the engine oil and filter be changed in my Equinox?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#12)Why do I hear a momentary motor or clicking noise when I start my engine and begin to drive away?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#13)How much can my Equinox tow (trailer weight)?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#14)How should I adjust the head restraint so that it's in the proper position?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#15)How do I use the window lockout switch?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#16)Why does the radio continue to work up to 10 minutes after the ignition key is turned to OFF?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#17)What should I consider when using the luggage carrier to stow cargo on top of my Equinox?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#18)What are some important points to consider when I decide to pull a trailer?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#19)How do I determine my vehicle's maintenance needs?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#20)Why is it sometimes difficult to shift out of PARK (P) when I am parked on a hill?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#21)My radio appears to get louder and softer depending on how fast I am traveling. Is it working correctly?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#22)What should I do if my remote keyless entry transmitter does not work, or I have to stand closer to the vehicle?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#23)What services are offered by On-Star?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#24)What should I consider when using the adjustable rear compartment storage panel as a table?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#25)Why won't the RDS features on my radio work when it's in the AM band?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#26)How often do I care for the CD player in my Equinox?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#27)How do I insert multiple discs into the 6-Disc CD Changer?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#28)How do I use the XM Satellite Radio service?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#29)How do I use the lumbar control to increase or decrease support?
(https://www.mygmlink.com/main/US/en/gm/vehfaq?vehid=1509034&actionpage=5_0#30)https://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifhttps://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifHow do I turn off the Daytime Running Lamps when necessary?
https://www.mygmlink.com/images/US/en/gm/gm_bdy_spacer.gifTo idle your Equinox with the DRL off, move the shift lever to PARK (P). The DRL will stay off until you move the shift lever out of PARK (P). To override the DRL on manual transaxle vehicles, your must set the parking brake while the ignition is off and then start your vehicle. The DRL will stay off until you release the parking brake. As with any vehicle, you should turn on the regular headlamp system when you need it.
Google
Web AF
