noobie toyota ownerjason-1995fbody 02-14-2006, 07:46 PM ok the story is my dads civic burned to the ground http://www.automotiveforums.com/vbulletin/%5Bimg%5Dhttp://files.automotiveforums.com/gallery/watermark.php?file=/503/280513burnt_civic.jpg%5B/img%5Dhttp://files.automotiveforums.com/gallery/watermark.php?file=/503/280513burnt_civic.jpg he had a 89 toy 4x4 truck so i asked if he wanted to trade for my metro http://www.automotiveforums.com/vbulletin/%5Bimg%5Dhttp://files.automotiveforums.com/gallery/watermark.php?file=/500/280513000_0350-med.jpg%5B/img%5Dhttp://files.automotiveforums.com/gallery/watermark.php?file=/500/280513000_0350-med.jpg :evillol::evillol::evillol: and he said 53 mpg :grinno: ill take it so the question i have is the engine light is on how do i get the codes with out a scanner thank in advance KimMG 02-15-2006, 03:12 AM Try autozone or one of the other major chain parts stores and see if they will read the codes for you. SidneyCanada 02-26-2006, 10:10 AM About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered. To pull the ECU codes: All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it: http://autorepair.about.com/library/ts/obd-i/bl-dtcs-36.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-53.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-71.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-90.htm http://www.off-road.com/toyota/tech/codes/index.html http://lcengineering.com/TechNotes/TechNote12.htm http://lcengineering.com/TechNotes/TechNote13.htm http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Engine.html http://www.mad-mechanic.com/toyota/toyotaobd.shtml#obtaincode http://www.freewebs.com/th3duke/22RE-ECU.mht http://www.troublecodes.net/Toyota http://members.igateway.net/~pscott/enginecodes.html http://www.autobook.co.kr/data_links/toyota_trouble_codes.htm http://www.autoshop101.com/forms/h27.pdf http://www.showmesome.info/hilux/info/manuals/1KZ-TE/Page0096.htm http://www.efisakh.narod.ru/at_toyota.htm http://www.usatransdoctor.com/foreigntoyota.htm Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio. Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:sidneybek@yahoo.com Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM http://groups.google.com/group/hfx.forsale/browse_thread/thread/43940ce83231ab85/4e4c696fbf04837f?q=sidney+tv+repair&rnum=1#4e4c696fbf04837f http://www.iwaynet.net/~nesda/May02/May18.html http://www.iwaynet.net/~nesda/SonyAudMod.html http://www.newark.com/product-details/image/mcm/image/32-9495.jpg http://www.tipsmaster.ca/hottips-1.HTM http://www.tipsmaster.ca/1011-TV32C50-007.jpg http://www.iwaynet.net/~nesda/June03/June0315.html http://www.iwaynet.net/~nesda/Apr03/Apr033.html vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
