camber kit creek
strodda
06-24-2002, 12:43 AM
recently when i come to a stop or start up, the right front makes a creeking noise. is it caused by the camber kits polyurethane bushings needing more grease? if not, whats going on?
Dezoris
06-24-2002, 03:00 PM
What car, what kit? What wheels, how many miles? How low are you?
strodda
06-24-2002, 06:38 PM
i have a 91 accord lowered 2" on speedtech's. about 130k miles. installed an ingalls anchor bolt kit /w poly bushings. right now, on stock rims, till i get new tires
Dezoris
06-26-2002, 10:00 PM
Well, this is hard to troublehoot, but some possible reasons.
1.)Blown shocks
2.)Creaky Frame
3.)worn shock mount
4.)Overtightened lug nuts on your wheel
5.)A-arm issues/bushings/balljoint
Check those areas.
Pull off your front tires, and inspect the a-arm assemble, and make sure it the mounting points are tight, and check the balljoint etc.
strodda
06-27-2002, 01:27 AM
thanks. ill try taking off the arm and re-greasing the points. if that doesnt work, ill just take it back to the shop and complain that it started making that noise after i got the alignment.
