Throttle stickingkelcher 06-23-2002, 07:58 PM I have a '99 Silverado 1500. I really like the truck, but lately the throttle has been sticking. I really have to press on the pedal to get the gas flowing. Have any of you been having this problem? DO you know how to fix it? chriscampbell 06-24-2002, 09:45 PM Common problem:) just take the air duct off of the throttle body and take some good carb cleaner and spray out the throttle body. Hold the throttle open and spray the throttle plate and bore out good, even take a rag and scrub the bore and plate. There will be a black buildup you will need to clean out, it causes the throttle plate to stick in the bore. Be carefull not to spray too much cleaner back into the intake it might flood your truck out. Hop this helps!!;) Puffnstuff 06-25-2002, 05:42 AM Focus your cleaning effort on the plate hinges. While you're there look at the bottom of the tb to see if the plate has been making contact with it. My tb was replaced per the tsb but I still have to clean it every so often or it'll stick just the same. :D kelcher 06-25-2002, 08:32 AM Thanks for the help. I will dig into that and clean it up a little and see how that works for me. Thanks again. kelcher 07-26-2002, 11:30 AM Guys, Thanks for the help, that seemed to really work well. wierjk 08-04-2003, 02:00 PM Thanks... this worked... the sticking is gone...wow... in one day I have found answers to all my problem ... this is great... Thanks again :bigthumb: :bigthumb: :bigthumb: wierjk 08-04-2003, 05:15 PM Thanks... this worked... the sticking is gone...wow... in one day I have found answers to all my problem ... this is great... Thanks again :bigthumb: :bigthumb: :bigthumb: adoberunner 12-28-2003, 02:55 AM I myself had this prob with my 99 Z. No I can drive without making jackrabbit starts everywhere!!! Many thanks!! Saltymut 12-28-2003, 09:54 AM This was too easy !!!! I thought I was going to have to take it in to the dealer, and let them charge me an arm and my left "lug nut" to replace something expensive. Carb Cleaner $2.99, at local auto supply house.... Labor $0, in my driveway... The fact that I don't have to smash on the peddle to get moving $PRICELESS !!!! Thanks guys. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
