Royal Purple WOWjers99z 02-10-2006, 05:43 PM I switched the oil and trans fluid in my truck to royal purple and i've noticed a difference and i really like it. The truck feels smoother and the shifts are really nice. well just wanted to put that out there, and im hopefully changing the diffs soon so if anyone has any adivce let me know. thanks. BlenderWizard 02-10-2006, 09:20 PM What did you do to switch your tranny fluid to RP? Was it all flushed out, or did u just drop the pan and add 5 quarts? silveradoking 02-10-2006, 09:54 PM I have used royal purple since I got my truck.........And the first time I put it in my truck felt like a airplane......(note: I also put royal purple in my transfer case, and heard knocking noises, bad idea..........the ONLY fluid you use is the Auto trac 2.....and no other one......everything esle bangs.....)...........Funny thing is that I just finished changing my fluids about 1/2 hour ago........Changed my engine oil, transmission fluid/ filter change, front and rear axles with royal purple, transfer case with the Auto Trac 2, and fuel filter...........I also clean the half ton of grass, and soil under my truck......(from the off-roading)........funny grass can come in weird places.....Anyways, it only took me about 6- 7 hours to do, and my garage floor, looked like world war three, had come....... But when I took, the truck out man it felt like I had a mach 10 vehicle, it really does give you more horses, for sure, especially the rear diff change......Anyways, tommorrow the new powerslots will be going on, with new pads, and new brake fluid........I will also, try to change out my collant as well.....Royal purple RULES...........Sorry, for bragging on........ silveradoking 02-10-2006, 09:56 PM You should flush your system first but not through the machines, and then just change your fluid with the filter, every 30-40 k....... jers99z 02-14-2006, 06:19 AM sorry for the late post, i did have the whole tranny flushed including the torque converter, 4l60 takes 11.2 qts to do. had to take it to the shop and have it done. still havnt done the diffs yet but i will keep in mind the auto trac. now is that only for the front or what. thanks silveradoking 02-14-2006, 05:12 PM Not sure on your question but......... Front Diff-Royal Purple 75w90/ 2 1/2 quarts.......then Transfer Case-Auto Trac 2- 2 1/2 quarts......and then Rear Diff-Royal Purple 75w90 2 1/2 quarts......hope this helps.....Royal Purple does not make a 85w90.......but it is perfectly safe to use 75w90 instead.......... jers99z 02-14-2006, 07:11 PM yep answered the question perfectly, thank you. sorry if it was a little confusing jveik 02-15-2006, 09:45 AM so if you use royal purple in your engine, are there any long term results yet about how long the engine running with royal purple will last? theres lots of snake oil out there ya know, and it sucks to fall for one, so you have to be damned sure its the real deal lol. As for the differentials, is the certain weight you put into them of royal purple actually able to be put into posi-traction units? at least on older chevy posi units, you had to go get an additive to put in with the gear lube 90 or else the posi would go out soon or wouldnt work in the first place... happened to a kid i know with a camaro, the posi wouldnt work until he put the gm additive in there vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
