93 pi w/ egr trouble code and vibration from shaft/axle
kwilli77
02-10-2006, 03:30 PM
I have a 93 crown vic interceptor.
I ran the codes due to a check engine light and got back 4-5 EGR trouble codes - would this most likely be the sensor or the valve and where are they located to change. I've had a few people suggest I try cleaning the valve out with carb cleaner as they tend to get clogged. what is the general opinion of doing this.
also going down the road I get a fairly regular - though not constant - vibration from around the drive shaft/axle area - I checked and the u - joints are fine, what else could the problem be.
I purchased a 92 vic lx about 6 mos ago and was rammed last week so I am trying to get the 93 up and going again - which needs alot of work - mainly with the engine - oil leak, freeze plug leak, etc - I plan to pull the engine from the 92 and rebuild it like a mustang motor - would I just be better off trying to obtain the 351 windsor to run - which has a better track history of durability and reliability.
