99 Escort Feelers~should I?
jdmetro
02-09-2006, 06:38 PM
I am thinking about buying a 1999 Ford Escort. I don't know much about it. [brother-in-law of co-worker] He wants $2,000. Have not seen it yet. Has 120,000 mi. Should I ask if timing belt was changed? Are these motors non-interference? Any INPUT would be appreciated. I'll know more when I drive it and meet the seller.
AltecZX2
02-09-2006, 07:11 PM
2door or 4 door? (they have different motors)
either: yes ask if the belt was replaced, if not...replace it
2door: motor is NON-interferance
4door: motor IS interferance
Both are very good motors(will take 200k+ if taken care of)...I have a 2door now...and looking into a 4door or a v6 94-98 stang for a 2nd car.
jdmetro
02-10-2006, 03:04 PM
Altec: Do you have a roundabout cost on a mechanic-replaced timing belt? With that entered into the picture , how does a $1,900.00 asking price sound?
AltecZX2
02-10-2006, 03:17 PM
Belt replacement shouldn't be much. (not sure what they run ive always done my own).
As long as the car drives fine and has no shifting/turning problems it seems like a nice deal.
chevyn0va1
02-10-2006, 03:45 PM
I got to ask how do you figure about the differnt motors for the differnt body styles?
chevyn0va1
02-10-2006, 03:47 PM
One thing I have heard is when you are having the t belt serviced its a good time to do the water pump for if you dont the pump fails right after and the t/belt has to come off for repllacement. So the thought is to do it while the belt is off the first time. BTW autozone.com has a good how to guide on doing the timing belt
mightymoose_22
02-10-2006, 04:07 PM
If it goes to a shop they will convince you to change the water pump... pump + belt + labor, you should expect to spend a couple hundred dollars easy. If you do it yourself... pump + belt... maybe $75 and a few hours of your time.
AltecZX2
02-10-2006, 04:30 PM
the 4door is a SOHC SPI motor (Escort)
the 2door is a DOHC Zetec motor (Escort ZX2)
jdmetro
02-10-2006, 07:48 PM
It's a 4 door. That scares me.:eek:
AltecZX2
02-10-2006, 08:39 PM
why?
chevyn0va1
02-10-2006, 10:52 PM
the 4door is a SHOC SPI motor (Escort)
I was told the shoc motor ( which I have and a 4 door) is non inter and the dohc is. Sure your not mixed up?
Davescort97
02-11-2006, 08:05 AM
Yes, that is true. The 91 to 96 1.9 and the 97 to 2002 2.0 SPI are both noninterference engines. The 91 to 96 1.8 are interference engines. Also, the 2.0 Zetech is an interference Engine. My sources are Gates rubber and Dayco belts.
AltecZX2
02-11-2006, 12:00 PM
the Zetec is a NON-interferance engine...your sources are wrong..the Zetec is NOT interferance
jdmetro
02-12-2006, 02:43 PM
Regarding the 1999 Escort 4-Door, you guys got me all balled up! Which is it; interference or non-interference??:disappoin :killbarne
chevyn0va1
02-12-2006, 04:06 PM
without getting anyone upset, I think you should look on this board more. As I recalled the sohc is non interference. Untill I'm proven wrong I'm sticking with that.
dougand3
02-12-2006, 05:23 PM
The way I read this pdf...All 1997 - 2002 2.0L Escort engines are NON-Interference...both SOHC and DOHC are NON-Interference.
Take a look. You'll need Adobe Reader.
http://www.gates.com/downloads/download_common.cfm?file=TBR05.pdf&folder=brochure
Davescort97
02-15-2006, 05:37 AM
You are right. lst generation scorts from 1981 to 1990 are interference engines. 1991 to 1996 1.9 SOHC are non-interference engines. 1997 to present 2.0 SOHC and DOHC engines are both non-interference engines. I stand corrected on this.
jdmetro
02-15-2006, 07:03 PM
thank you!! :sadwavey: :thumbsup:
