Page updated on 06-21-2018
ABS Sounds like leaking air when pressing on the brakes
zander5
02-09-2006, 01:32 PM
1996 Gr Voyager, I was backing out of my drive way and applyed the brakes .The pedal went to the floor, A sound from undernieth like pressure was being released. I looked under, no leakes of fluided,if you pump the pedal it may hold or may not hold, check vaccum to booaster,ok any ideas. Thankyou:banghead: :banghead:
GTP Dad
02-09-2006, 01:40 PM
Bad master cylinder or a bad rear wheel cylinder. It can leak fluid and it would not be seen. Check both as soon as possible and don't drive the car. Also check for a vacuum leak at the booster and the intake manifold. Make sure the vehicle is running when you test for a vacuum leak.
zander5
02-09-2006, 02:05 PM
Bad master cylinder or a bad rear wheel cylinder. It can leak fluid and it would not be seen. Check both as soon as possible and don't drive the car. Also check for a vacuum leak at the booster and the intake manifold. Make sure the vehicle is running when you test for a vacuum leak.The sound is coming from the ABS area, I checked the vacuum line to the booster and strong vauum, andI will check the read wheel clyinders. thanks
GTP Dad
02-10-2006, 09:49 AM
Since there is no air in the system the problem has to be with vacuum. There has to be a leak somewhere. It could be in the vacuum booster itself as it can be leaking from an area that is inaccessable without removing it.
zander5
02-10-2006, 02:03 PM
The sound of pressure being released is in the area of the ABS system under the van and you only hear it when pressing on the brake.If you pump the brake pedal many times you get a slight brake pedal and no noise under the van of the ABS system:banghead:
zander5
02-12-2006, 07:14 PM
The problem was corrected, I removed the left rear brake drum, noticed the wheel cylinder was leaking and replaced both rear wheel cylinders and brakes. The sound did not return.
RIP
02-13-2006, 03:16 AM
zander5 - Thank you so much for letting us know the fix! You and the moderator have surely saved many bottles of asprin across the country. Cheers!
