interior lights deadrusty99 02-08-2006, 02:47 PM I've had intermittant problems with the interior electrical system on a 2004 model and now the interior lights will not work at all when the doors are opened. There is no mention of an interior fuze in the fuze box in the engine compartment( all those fuses OK). Does anyone know if there is another fuze box hidden elsewhere? Maybe somewhere in the passenger compartment? thanks for any help. 4432flying 02-08-2006, 07:40 PM I've had intermittant problems with the interior electrical system on a 2004 model and now the interior lights will not work at all when the doors are opened. There is no mention of an interior fuze in the fuze box in the engine compartment( all those fuses OK). Does anyone know if there is another fuze box hidden elsewhere? Maybe somewhere in the passenger compartment? thanks for any help.I have a 2002 venture and all of the interior lites can be turned off with the doors open by a rocker switch on the left side of the upper switch console below the front dome lites. Make sure it is not switched off. Good luck. GregA 02-08-2006, 09:01 PM I have a 2002 venture and all of the interior lites can be turned off with the doors open by a rocker switch on the left side of the upper switch console below the front dome lites. Make sure it is not switched off. Good luck. Definitely check that switch that Flying mentioned, but also check the fuses on the Passenger side of the dash (open the passenger door to see the cover). You can see them at the link below (top picture). I believe it is fuse #35 on the list. Chevy Venture Fuses (http://www.my-chevy-venture.com/fuses.html) Take Care, vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
