Hey I thought my 96 had posi....>>
GirlBear
02-07-2006, 11:20 PM
Apparently not! Did powerbrake 2day only 1 wheel smoked. only 1 tire make. wtf lol
BlazinMlew
02-07-2006, 11:26 PM
I thought we had limited-slip-dif ????
Oh what the hell am I talkin about I dont know anything:lol:
Teal95Jimmy
02-08-2006, 12:07 AM
on your rpo sticker in the glove compartment is there the g80 code, thats the code for a posi
also, sometimes you need to let go of the gas to get the posi to activate, that helps on mine in really slick conditions
OverBoardProject
02-08-2006, 09:51 AM
I do have a posi, but 1 day while spinning in a mud pit I only had 1 rooster tail of mud flinging.
I couldn't believe that I actually had to put it into 4wd to get out :headshake
So the next day I changed the oil, and it started working again.
maxwedge
02-08-2006, 12:34 PM
The G80 is not a posi unit, it is a locking diff, when one wheel spins at about 100 rpm more than the other a governor locks the unit up, .
Jeremy Fitch
02-09-2006, 07:07 AM
Do you have to add any thing other than the gear oil if you have the G80 code when you change the oil out? Posi additive?
Brian R.
02-09-2006, 08:46 AM
Lockers use standard gear lube and no additive.
blazee
02-09-2006, 10:39 AM
Just make sure that you get the stuff that is okay for a complete fill. Some of it says "for top off only" in small print on the back.
OverBoardProject
02-09-2006, 11:00 AM
My 85 requires an additave, but I can't speek for the newer units.
I didn't use a gasket, just high temp silicone. Next time I'm using both.
