99 tahoe problemsmikef 06-21-2002, 08:55 PM on inclines my tahoe begins to shudder violently until I back off the accelerator. Can anyone help or tell me of a web site that can? Johnny_G 10-01-2002, 01:35 PM Did you ever get this problem fixed? I just replaced my EGR valve ($290) and am hoping that is gonna do it. what was yours? KellyB 04-08-2003, 10:46 AM Had the same problem, Do you have a K&N filter? If so Ckeck the Mass air flow sensor between filterbox and intake. Oil from filter can coat sensors giving them false reading undetectable in engine codes. Spray a little carb cleaner on three small horizontal wires( look like lightbulb filements) running between vertical bars. Worked wonders on mine. 99gmcyukon 07-06-2003, 12:47 PM Did this work? I am having the same problem with my 1999 GMC Yukon. No one has been able to tell me what it is. They replaced a U-Joint, but that did not fix it. It makes a really load whirring/roaring noise along with the shake any time I am over 55-60MPH it happens. It is not the tires because it only happens when I am pressing the gas pedal. jdod85 07-10-2003, 07:48 PM It seem this is a common problem with the 99 and 2000 GM pickups. With extended cabs. Check out htis web page for more help http://agmlemon.freeservers.com/ ronkh 01-29-2004, 09:22 PM I have a "roaring noise when I back off the accelorator partially. Did that happen to you? Also the shutterring happens when going uphill under a load. I was told to ck the vacume booster on master cylinder since it seems that the roar is coming from behind the left vent/tach area. And that the shutter may be from the brakes pulsating (ie. abs) Did this work? I am having the same problem with my 1999 GMC Yukon. No one has been able to tell me what it is. They replaced a U-Joint, but that did not fix it. It makes a really load whirring/roaring noise along with the shake any time I am over 55-60MPH it happens. It is not the tires because it only happens when I am pressing the gas pedal. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
