automatic climate control - dual zone
PA93
02-04-2006, 10:32 AM
Does it work at all?E.g. would I fell it if I set different temp for driver and passanger?Or maybe 'dual zone' just sounds good?:) I can't check it because it's too cold here :/
imidazol97
02-05-2006, 11:20 AM
In heat mode or in air conditioning it's supposed to be able to vary the temp on passenger by up to 15 degrees or so. If heat is set at 82 on driver and all way up on passenger you're not going to tell a diff. But I like 80 on driver and wife likes 70 on passenger so she's always setting it different. You can tell the air coming out of two dash vents are different on the passenger--at the bottom on floor it's hard to tell but the air goes through two different ducts for passenger and driver.
