Removing TRD and Taco DecalsFaceTime 02-03-2006, 09:19 AM What is the best/easiest way to remove the TDR decal, and the Toyota, SR5, etc., decals?:1zhelp: TacomaPilot 02-05-2006, 08:20 PM I'm not sure about the other decals you are referring to, but the TRD shouldn't be too hard to remove. Best thing to do is to get the decal very warm, either park the truck so the sun beats down on it, or use a hairdryer or heat gun to warm it up. It may be hard to start the removal with just your hands, so if you can get a hold of a plastic razor blade, that might help to start it and pull the decal off. Depending on how old the decal is, it will likely just come off in small pieces so plan on it taking some time. When you get the decal off, use some wax and adhesive remover (3M makes one safe for auto paints) to get off any adhesive residue that may remain. FaceTime 02-05-2006, 10:06 PM I'm not sure about the other decals you are referring to, Thanks for the info:grinyes: The other ones are the "SR5," "Toyota," etc. I would guess the same process would work . . . or are those adhered some other way? TRD-TOYZ 02-07-2006, 04:02 AM vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
