View Full Version : question for Schlud or OffroadX
Preacher35
02-03-2006, 07:25 AM
Since you guys seem to be the only knowledgeable people to answer questions on this forum, I'm directing this question at you: Do you think that an ARB off of an '03 X will be compatible with an '00? I found this on Ebay:
http://cgi.ebay.com/ebaymotors/Nissan-Xterra-ARB-Winch-Bumper-Bull-Bar-Grille-Guard_W0QQcmdZViewItemQQcategoryZ33585QQitemZ80352 75171QQrdZ1QQsspagenameZWDVW
What do you think?
Thanks in advance.
OffroadX
02-03-2006, 09:27 AM
Yes, it will work. They changed them a bit to fit the 02+ style but it's backwards-compatible just fine.
Brent
Schludwiller
02-03-2006, 04:20 PM
The 2002+ ARB's have the triangle-uprights shorter to create more distance between the front of the bumper and the grille due to the 2002's thicker headlight/grille. So imagine a triangle and the base of the trianlge was made shorter. What that basically will do is make the gap betwen your 2000 grille and the front bar longer. Not a big deal, but just so you know. Everything else is the same.
Schludwiller
02-03-2006, 04:24 PM
BTW, I believe and ARB is only 80lbs, so don't let him screw you on shipping as I see he noted it as 150-200lbs.
Preacher35
02-03-2006, 07:12 PM
Thanks fellas, as sual! BTW, I called 4Wheelparts and they stated that the ARB was, indeed around 150 lbs.... But, I appreciate the heads up, nonetheless!
Maybe it was an 80lb increase over a stock bumper....It's been 4 years or so. :D
Schludwiller
02-03-2006, 10:16 PM
Schludwiller
BTW, sorry about the "edited by Schludwiller" on your post. I accidentally clicked on your post to reply and since I'm admin it lets me edit. It should be intact.
OffroadX
02-04-2006, 12:08 AM
If only you moderated the Yahoo board so vigorously...
Frickin' spammers run amok there recently, where ya been?
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
