1992 Chevy Lumina wheel bearingsdelicatedelinquent 02-02-2006, 05:04 PM Are these replaceable by the typical doityourselfer? maxwedge 02-02-2006, 05:54 PM Go to autozone.com/repairinfo and see if you think you can do this. richtazz 02-03-2006, 04:47 PM Other than a few special tools required (torx bit socket for hub to spindle bolts, axle nut socket for the big nut on the end of the CV axle, and a torque wrench to tighten everything properly), if you can do brakes, you can do a hub bearing on that car. BCA/timken number is 513044, just for reference. maxwedge 02-03-2006, 05:07 PM 60mm heavy duty Torx, and 36mm axle socket, just to add to Rich's info. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
