cv boot
aukster
02-01-2006, 10:01 PM
Ok I did search but did not come up with the information I need. I am replacing the cv boot and was wondering what needs to be done to replace it. Does the hub have to come loose? How do you get the clamps off? Thanks
Tommygunlee
02-03-2006, 07:17 PM
u should be a little bit more specific, but I hope u r changing the whole shaft and not just the boot. If u r then remove tire, brake caliper, steering knuckle from hub, then remove hub nut and pull shaft from hub and pop out shaft. sometimes strut may get in way but u should be able to work around it. this is not a easy job and a knuckle buster so if u r not somewhat machanically inclined and have the right tools then plan on a all day job. good luck.
