95 Rodeo 3.2 Coil pack
Google
Web AF
cubs06
02-01-2006, 06:25 PM
Sorry to start another thread guys but I'm about ready to pull my hair out!! Is there a simple way to check for a bad coil pack? With the engine running, I pulled each plug wire one at a time from each coil pack and each post on each coil pack emitted good spark except the last coil pack. One post was emitting good spark and the other post had no spark emitting from it. Bad coil pack??? Thanks guys!!!
amigo-2k
02-01-2006, 07:05 PM
If you have a bad coil pack it is toss a code (CEL; check engine light) for a missfire. Now that doesn't mean the coil is bad. To test to see if the coil is bad you would move that coil do if different location and see if the missfire code move to the new cyclinder.
This is based on +98 setup that have a coil over each cylinder that can be moved to another cly.
cubs06
02-01-2006, 09:43 PM
YES!! YES!! YES!! YES!! YES!! Thank you all so much for your help!! I checked the coil packs and the coil pack I had to replace a couple of years ago which was a wells from autzone was only emitting spark from 1 post and not the other!! Went to advance a bought a gp sor. and bingo!!! Runs like brand new again!! Once again thank you all for your help!! I was so afraid when I replaced the timing belt and everything else in there that I might og been off a tooth or two and would have to do all over again!!! YEE haw!!!!
surferfletch
02-01-2006, 10:17 PM
Glad you got it!
When I did my belt a few months ago, I found it was off a couple of teeth. It didn't seem to make a big difference. On the other hand, when my little 2.0L Jetta was off a tooth or so, it ran like crap.
Google
Web AF
