92 rodeo - hard start and idleanklenawer 02-01-2006, 05:16 PM alright, seemed like fuel filter - after that was replaced,. it still does it..it will only start if i slam the gas pedal and start it.. also.. about 600-700 rpm idle.. and somtimes quits at stops.. anything before i go to fuel pump?.. i don't wanna replace one of these fuckers.. by the way - it runs great after start.. i can run the piss out of it, but until i come to a stop.. it shits out on me.. haha well anythign would be appreciated.. anklenawer@hotmail.com if you got anything.. thanks dudes -kyle paulsantangelo 02-03-2006, 12:57 PM Firstly you got to watch the language, you get bees with honey, ya know! Before replacing fuel pump, take off the air cleaner cover, try to start. Note; is there any oil in the air cleaner? Check ALL vacuum hoses for leaks that come off the TBI unit, of course I'm assuming this is a 3.1 L rodeo. Please be specfic as to your engine type. If there is a lot of oil you might try carb cleaner in the butterys and the bypass which is located right over the IAC. EGR could be an issue to, press on the diaphram, if there is little restance, thats OK, but if you have to force it, then its bad. I do know that if you remove the vacuum off the accessory line (check the hood), your idle will go up. this might help determine if you have a vacuum leak. If you remove the line that goes to the air temp sensor and your idle does not go up, it cold be another leak some where. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
