94 escort ran out of gasbbahur 01-31-2006, 03:14 PM i have 94 escort that ran out of gas, now the car wont start. any troubleshooting ideas would be greatly appreciated. dougand3 01-31-2006, 04:45 PM It's possible that garbage at the bottom of the tank was pulled up by the fuel pump and clogged part of the fuel delivery system. Check if this model has a fuel cutoff switch or breaker - if so, make sure it is reset. I'd change the fuel filter definitely - probably on the firewall, almost centered. If no joy, then I'd inspect fuel pump and fuel injectors. KimMG 02-01-2006, 03:55 AM Since there was no gas to lubricate the fuel pump, it may have burned up. Check to see if you have fuel pressure. Scott Wiiki 02-01-2006, 03:19 PM I bet it's the fuel cut off switch. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
