speedometer to fastoldchuck 01-31-2006, 11:19 AM When the car is going 50 the speedometer is showing 85. It is a 92 lumina sedan.I know it has a sensor on the right axel housing , but is the trouble in the sensor or the pcm.? richtazz 01-31-2006, 12:00 PM have you changed the transmission or guage cluster prior to the speedo reading way off? oldchuck 01-31-2006, 06:36 PM No I have not changed anything, also the cruise does not work. The hand moves smooth but shows to fast . Can the sensor be dirty and getting the wrong signal? oldchuck 02-03-2006, 09:13 PM Hey whats going on ?I don't seem to be getting any help. richtazz 02-04-2006, 10:52 AM has the speedo always been off, or did this recently happen? oldchuck 02-04-2006, 06:15 PM I had this problem when I got the car. It has the right size tires ,so what is going on? It has the sensor with 4 bolts instead of the one bolt hold down type. I checked the wiring .it seem ok. the speedometer goes back to 0 when I stop. Works smooth does not jerk or anything. oldchuck 02-08-2006, 02:34 PM Alright were is all the answers to my problem with my speedometer? I know there is somebody out there with this problem. richtazz 02-08-2006, 05:25 PM I would pull the cluster and see if the sticker on the back matches the vin on the car. It sounds like the cluster was swapped with one from a different year and it's calibrated differently. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
