problems with clutch install
View Full Version : problems with clutch install problems with clutch install Retard324 01-29-2006, 06:15 PM is there anyway i can remove the harness to the trans or could i just take the sensors out? that sounds like it'd be a bad idea but it seems like the last possible thing i can do about them. i havent been able to drive the 240 in almost 2 weeks and its killing me. missed so many good oppurtunities to go drifting too... this is so gay, please help. Hit_N_Run-player 01-29-2006, 06:55 PM You can try and find it here. http://www.alldatadiy.com/alldata/AFI~V6094637~C10015~R0~OP~N/0/34870051/56619938/56620797/56620798 If you cant login its... LOGIN-TRAIDMACHINERY PASSWORD- 4530ne148th nissanfanatic 01-29-2006, 07:15 PM The connectors shoudl come right apart. From my expirience with gay plastic connectors... it is always much easier than you think. Just take your time and examine the connectors to find out how they come apart. Hit_N_Run-player 01-29-2006, 07:47 PM The connectors shoudl come right apart. From my expirience with gay plastic connectors... it is always much easier than you think. Just take your time and examine the connectors to find out how they come apart. yeah, same here. Sometimes ill try and try, then look to find i was just doing it wrong. Then it only takes a easy click once i figure out how it really comes apart. You might need a pick if you cant get part of the clip apart also. Retard324 01-29-2006, 08:05 PM i'll spend the night under the car tonight and figure out what i'm doing wrong, thanks. i checked out AllData and another site, like Epnet, and read up on it. http://240sxforums.com/forums/showthread.php?t=66413 link to info on Epnet, its great sidewayzS13 01-29-2006, 08:55 PM freshalloy is always a good place to check out for any questions as well Hit_N_Run-player 01-31-2006, 07:49 PM if it's that hard cut the wires and crimp them back together lol just don't break the locks(little piece u have to lift up) or you will have to use a ziptie to hold the connector back together securely ziptie for holding connectors togethor is wack!!lol. id just buy new connectors or cut/crimp wires if it was that hard. Retard324 01-31-2006, 10:25 PM i gave up and took it to a shop. turns out the flywheel i ordered doesnt fit anyway... kinda gay, would of had it back today but no, there had to be another problem so i cant drift with the guys tonight... but yeah, thanks for the advice anyway. i'll keep it in mind when my clutch goes out next time... didnt even think about recrimping the wires. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
