Passkey
Google
Web AF
Delori
01-29-2006, 03:31 PM
Can anyone tell me the passkey is located in a 05 tahoe? :banghead:
I'm installing an alarm and can't find it.
Thanks,
Delorian
Delori
01-29-2006, 06:04 PM
I'm installing a Crimestopper 2016FM and a Directed 457GW in a 2005 Tahoe.
For the 457, the 3 pin connector says to cut the pink ignition wire to the PK/Passkey and connect the pink/black and pink wires to it.
I can't find a blackbox labled PK, Passkey anywhere under the dash. Can anyone let me know where this bugger is hidden or another connection location?
Thanks for any help,
raycorri
01-31-2006, 01:44 AM
in a 2005 Tahoe.
Isn't 2005 Tahoe Passlock II? Here's what I found --
2005 Chevrolet Tahoe
Category: Immobilizer Bypass
Required: Yes
Type: Passlock II
Part#: 556LW
Notes: Not required if using the combo interface module. The Passlock II wire colors are yellow, black, and red/white (not used).
Alternates: 555LW, DesignTech 20402, DesignTech 29402
Category: Combo Interface
Required: Yes
Type: Data Bus
Part#: 457GW
http://www.directwholesale.net/diagrams/printpage.asp?ModelID=16670&MakeID=54
You will not have a transponder box under the dash. You need to find the 3 Passlock wires as they exit the Ignition Lock Cylinder as described in the link above. Hope this helps.
Ray
Proud Member of The Anti-Passlock Club:smokin:
Delori
01-31-2006, 11:10 AM
Thanks, I got it working last night. It turned out to be a bad connection on the inline fuse for the 457. I guess I didn't know I had to test their connections too! :screwy:
Thanks,
Delorian
Delori
01-31-2006, 11:34 AM
Two more questions. When I disarm, the dome light comes on, but not the parking lights. My wife wants this option. I checked the programming and they should be on by default. I reprogrammed it to make sure, still no luck. They do flash during arming and disarming so I know they are connected. I was also dark enough so I know the photo cell didn't have anything to do with it.
Also, if it is already armed and I hit the lock again, the alarm sounds like I held a button for panic alarm. Is that normal for Tahoe?
I install the exact same alarm in my 91 mustang (minus the 457) and all is working fine on it.
Thanks,
Google
Web AF
