Driver Side Master Window Switch?
Google
Web AF
steel120
01-27-2006, 09:01 PM
I have a 1995 Lumnia LS with the 3.4 engine. The problem is the master window contol switch cluster is not working properly..Passenger side and rear windows work fine from the respective switch on the door. The Drivers side window switch will lower fine, will go up, but have to push hard on the switch to get it to go up..its not binding and goes up fine once the contacts on the rocker switch engages..It is most likely corroded/worn out..
I pickup up a switch from another Lumnia(recycled) but the layout of the switch connectors is different from the orginal unit.
Anyone know of what is what on the switch harness? I most likely need to
move some of the Pins around on the switch harness plugs.
I have a photo of the two switches, however, I do not see how you attach the photo..If anyone can help..I could email the photo of the switches comparison.
Anyone have the color codes of what is what on the two harnesses plugs?
How they may be mapped to the switch assembly?
I have see notes on the aftermarket switches indicating a modification may be required to the wiring(harness plug) to use the newer switch, but no other info..
Thanks Bob...
maxwedge
01-28-2006, 09:58 AM
Get the right one in a salvage yard.
richtazz
01-28-2006, 10:47 AM
the switches off a newer Lumina with the lock out function are incompatable with older cars without. No matter how you rewire it, it's not gonna work properly. I agree with Maxwedge, get the right one and save yourself a lot of headaches.
Google
Web AF
